oil pan stuck
Old Mar 9, 2011 | 03:21 PM
lazyxmofo's Avatar
Default oil pan stuck
well im changing my oil pan gasket and i took all the bolts off the oil pan..but its stuck in the transmission case...is there a way to get around this??
Old Mar 9, 2011 | 03:25 PM
vrrodri's Avatar
Default Re: oil pan stuck
You mean you did not remove the flywheel cover? You need to do that to access the remaining bolts on that side.
Old Mar 9, 2011 | 04:29 PM
91_LS's Avatar
Correct,and there should be 2 more bolts to the pan as well.
Old Mar 9, 2011 | 06:26 PM
lazyxmofo's Avatar
yeah im finally done...thanks
bopbop93030
Jul 4, 2009 06:40 AM
AF-b16a1
Aug 2, 2004 09:53 PM
02 coupe
Jun 25, 2003 01:56 PM
Loveless
Apr 23, 2003 04:57 PM
dynomax27
Oct 15, 2002 04:22 PM
