Del Sol torque mounts???
Old Mar 9, 2011 | 01:26 PM
JDMAF's Avatar
Default Del Sol torque mounts???
So I'm in the middle of getting a b16a into a 95 del sol s... I've never done a honda swap before but I will have no problem with the swap... Got the car with the motor out of the car... So I'm quickly learning what is missing... one thing I'm not seeing is the torque mounts... The car had been previously swapped using hasport mounts... But I'm not seeing the torque mounts that my 95 civic has... Do I need them???
Old Mar 9, 2011 | 02:19 PM
94EG8's Avatar
Seagull Management
Default Re: Del Sol torque mounts???
If you're using aftermarket (hasport/Avid/whatever) mounts then you don't need them, although i'd still recommend them. If you're running OEM mounts then you really should them.
dseriessol
Jan 1, 2011 09:46 PM
gooberguy31
Oct 29, 2009 03:56 AM
93blkdelsol
Jul 9, 2004 05:12 AM
bluedelsol
Jun 3, 2003 06:14 PM
