Fuel Gauge Stuck after swap
Old Mar 9, 2011 | 05:50 AM
hirogx's Avatar
Default Fuel Gauge Stuck after swap
i just swapped a eg ex gauge cluster into my eg dx ! everything works great except that the fuel gauge is stuck on full. i filled up my gas tank the other night and have been driving the whole day (total 50+ miles) and the needle doesnt drop even a bit compared to the dx cluster. ive been thinking about disconnecting the battery, reconnecting to see if that does the trick, if not, then maybe clean the terminals on the back of the cluster a bit? any pointers guys? thanks!
Old Mar 9, 2011 | 05:56 AM
fallrivercolin's Avatar
Default Re: Fuel Gauge Stuck after swap
My eg6 cluster in my eh hatch does that. I get over well over 100 km on the trip before the guage even moves, but the gauge works perfectly. I assume it is due to a difference in tank sizes between my EH and the sir-II. just keep driving it, and it probably will go down in another 50 miles. If not, check the connection and follow the wire back to the tank and check for breaks. If none of the above work, the cluster is bad.
Old Mar 9, 2011 | 08:46 AM
fungus mungus's Avatar
hirogx,
The fuel gauge is most likely broken. This often happens when someone removes the gauge from the back of the cluster and then, while putting it back on, tightens the screws too much. This breaks the connection, thus your gauge is stuck on full. You need to get another fuel gauge from a donor cluster and swap the gauges, this time CAREFULLY tightening the screws (not too tight now).
This should be a FAQ
fm
Old Mar 10, 2011 | 01:03 PM
hirogx's Avatar
ok so i tried cleaning the connecting points, still nothing...
Old Mar 11, 2011 | 06:46 AM
How far have you drivin it? I just got to 180km on mine before the gauge started to move.
Old Mar 12, 2011 | 07:59 AM
hirogx,
fm
90si-rex
Jul 7, 2014 02:17 PM
fitbmx86
Mar 9, 2008 11:24 PM
B6tizzleHatch
Aug 2, 2006 07:06 AM
compprat
May 11, 2006 11:14 PM
nicehatchy
Jul 4, 2005 08:12 PM
