Timing Tensioner replacement
Old Mar 9, 2011 | 05:31 AM
LeonardDB's Avatar
Default Timing Tensioner replacement
97 Civic Hatchback DX - Folks, I've read a ton of threads. Everybody seems to agree that on the 2nd TB change, you should replace the tensioner. From my point of view, the tensioner spring NEVER gets any wear. The spring ONLY gets used when you adjust the tensioner during the TB change. So why ever replace the tensioner as long as it spins freely and there is no roughness in the feel?
Old Mar 9, 2011 | 05:55 AM
94EG8's Avatar
Seagull Management
Default Re: Timing Tensioner replacement
If the the bearing feels good then I don't see much reason to change the tensioner.
Old Mar 9, 2011 | 06:47 AM
honda.lioness's Avatar
Originally Posted by LeonardDB
9Everybody seems to agree that on the 2nd TB change, you should replace the tensioner. From my point of view, the tensioner spring NEVER gets any wear. The spring ONLY gets used when you adjust the tensioner during the TB change. So why ever replace the tensioner as long as it spins freely and there is no roughness in the feel?
Like 94EG8 was saying, the bearings on the rotating part of the tensioner are the concern. I think re-using the spring for like five timing belt changes is fine.
I have read reports here of tensioners failing and so causing a timing (often catastrophic) failure. I advise the peace of mind of changing the tensioner at least every other TB change and checking the tensioner (as you suggest, by removing, turning, and noting bearing condition) each TB change.
Lambo123
Sep 7, 2009 10:25 AM
zeplin
Jan 25, 2009 07:44 AM
GsDAteg
Aug 6, 2007 07:52 PM
92B20GSR
Nov 17, 2003 02:04 AM
