GAUGE CLUSTER SWAP
Old Mar 8, 2011 | 08:38 PM
JDMb18c1HATCH's Avatar
Default GAUGE CLUSTER SWAP
before I get smashed on about theres already a 1000 trheads out there about this iv already searched and found them and read them but i have a Q that was not stated in what im looking at.
Ok my 92 civic hatch came with a gauge cluster that does not have the tac in it but I alreAdy have another one with the tac in it and today when I pulled the old one out of the car to put the new one In I noticed that there was only 3 wire plugs on the stock on in the car and i didnt see another wire plug in the harness
SO>>>>>>
what do I have to do to make the tac work in the 2nd cluster I have? do i have to find a wiring harness "in dash" that has the extra plug in it already or is there another way around it. im asking cause im sure the tac wont work without this 4th plug im assuming
Old Mar 8, 2011 | 10:19 PM
Former User's Avatar
Default Re: GAUGE CLUSTER SWAP
What car did the replacement cluster come from? Should be plu and play from a 92-95 Civic. Post pictures of the plugs.
Old Mar 8, 2011 | 10:22 PM
hirogx's Avatar
i just swapped a ex gauge cluster into my dx too! everything works great except that the fuel gauge is stuck on full. i filled up my gas tank the other night and have been driving the whole day (total 50+ miles) and the needle doesnt drop even a bit compared to the dx cluster. ive been thinking about disconnecting the battery, reconnecting to see if that does the trick, if not, then maybe clean the terminals on the back of the cluster a bit? any pointers guys? thanks!
Old Mar 9, 2011 | 12:27 PM
here ya go. and thanks for the help
tac 1 "the one I wanna use
tac 2 missing the white plug. "currently in the car"
tac 1 & 2 notice the differences "whats the extra plug for?"
The wiring harness currently in the car
Old Mar 9, 2011 | 12:29 PM
CaptivaBlueSol's Avatar
Is the TAC2 just a cover? From what I know it should just be plug n play. Aren't all civics wired from the factory to use a tach?
Old Mar 9, 2011 | 12:37 PM
no its not just a cover theres no plug behind it so its just covering the hole. Also notice the harness I have that came out of the car does not have the extra plug thats pictured on the back of the gauge cluster. so im curious as to what the extra plug is for and if its even needed and will the tac plug n play and work without that extra whit plug in the harness
Old Mar 9, 2011 | 12:45 PM
The missing plug socket in cluster #2 is only needed for the cruise control and shift up indicators. Cluster #1 should work fine.
Old Mar 9, 2011 | 07:52 PM
Ok awesome thank you so much for your help again in yet another build lol.
what is clerified here in this topic has not been clarified in any other one so this is a good one to hang on to
thanks again
Old Mar 9, 2011 | 08:01 PM
eghatch9295's Avatar
Stancetard Hate Monger
yep, that plug is for the shift arrow in the other cluster. your tach will work just fine.
KimChiKid
23
Jun 22, 2006 09:20 PM
aeboync
May 25, 2006 11:40 AM
LU
Nov 20, 2005 08:11 PM
bLaCkLuDe717
Jan 25, 2005 01:29 PM
fred92htch
Apr 25, 2002 01:57 AM
