**BRAKE GURUS... Enter here**
Old Mar 7, 2011 | 01:43 PM
Nate047's Avatar
Default **BRAKE GURUS... Enter here**
Hey guys, I have a question that hopefully someone can help me out with. I know there is a brake forum, but there are about 10 posts and no one reads it so that's useless.
I'm in need of replacement calipers for my rear brakes. I need something that will fit a 98-01 ITR 5 lug brake knuckle/rotor, that is NOT an ITR caliper. Reason being, the company that is supplying me with re-built OEM calipers does not offer ITR fitment because they are rare to come by. SO, I need an application that is more common, if such a thing exists.
Are there any other fitments i.e. Prelude, CRV, Legend, etc that will bolt on directly and work with ITR REAR pads/rotors/knuckle?
Thanks!
NH
Old Mar 7, 2011 | 01:58 PM
94EG8's Avatar
Seagull Management
Default Re: **BRAKE GURUS... Enter here**
EP3 calipers will work IIRC but you have to swap them from left to right.
Btw, have you considered rebuilding the ITR calipers? This is one of those rare cases where it might be worth it.
Old Mar 7, 2011 | 03:06 PM
Nate047's Avatar
thanks for the info, I will see if it's an option to send in my own calipers for rebuilding. anyone able to confirm the EP3/DC5 option?
Old Mar 7, 2011 | 09:33 PM
Nate047's Avatar
evening bump
Old Mar 8, 2011 | 12:28 AM
kyosoeg6's Avatar
honestly this is one rare occasion that i would say post or move this topic to the itr forum. those guys know more than honda about their own cars
Old Mar 8, 2011 | 03:30 AM
Libertariat's Avatar
Ek Forever y0!
I know there's a sponsor in the brakes/suspension forum that sells re manufactured OEM brakes. Might not be a bad idea to PM him and see if they offer a rebuild service.
Old Mar 8, 2011 | 04:53 AM
BryanM.'s Avatar
Resident Gearhead
Someone on here once posted that CR-V and ITR calipers had the same part number.
Don't know if it's true.
Old Mar 8, 2011 | 06:52 AM
94EG8's Avatar
Seagull Management
They do, but that was for first gens, and front calipers, all first gen CR-Vs had rear drums unfortunately. Second gens I can't remember if they look the same or not, third gens are totally different.
Old Mar 8, 2011 | 09:49 AM
Nate047's Avatar
this would be fine, Mods feel free
I will check that out, thank you
Old Mar 8, 2011 | 10:48 AM
NXSpoon's Avatar
I ran EP3 calipers on my 99 Si with ITR spindles/knuckles pressed into the Si suspension. Bolted right up, no mounting mods necessary. I ran them on the "proper" sides; however you must bleed them first, then mount them as the bleeder is on the bottom. Or you can mount the left on the right, and vice versa.
Old Mar 8, 2011 | 11:15 AM
BlueIntegraBoy's Avatar
EP3 calipers and RSX calipers fit.
Corksil
Nov 8, 2011 09:08 AM
the1
Suspension & Brakes
Nov 7, 2011 12:44 PM
Nate047
13
Mar 10, 2011 09:21 AM
Nate047
Suspension & Brakes
Mar 8, 2011 10:13 AM
