Blueprint Racing 103mm stroker kit
I am selling a k24 with a 103mm blue print racing stroker kit. This was my block from the 2010 season. It is a very realible kit that made good power 351hp 244tq and had no issues at all. I just freshened up the block with a light hone new piston rings and bearings, I am also including a new cometic head gasket a type s oil pump & baffle with a k24 steel oilpan as well. I am asking $4,700 for it. Give me a call if you are interested 917-847-7476. Here are the specs:
k24a4 block sleeved with aebs sleeves
blueprint racing 103mm stroker kit
blue print rods
blueprint crank
wiseco 15.1 compression 89mm with vertical gas ports
265 in valve pockets 190 ex valve pockets
type s oil pump
k24 oil pan
blue print rods
blueprint crank
type s oil pump
k24 oil pan
