Rapid Misfire on accelerator. Where to start?
Old Mar 7, 2011 | 08:31 PM
Naiyasin's Avatar
Default Rapid Misfire on accelerator. Where to start?
94 ls. Non-V. Rapid misfire on acceleration. Very occasional and sparattic. Sometimes it does it, sometimes not. Not too sure if this is relevant, but it bogs a little.
Info or help please. Share your experiences if you wish.
Ty in advance H-T.
Old Mar 7, 2011 | 08:32 PM
Naiyasin's Avatar
Default Re: Rapid Misfire on accelerator. Where to start?
Maybe plug wires? I already replaced spark plugs, cap, rotor, ecm, MR, fuel pump, none of the above fixed the issue.
Old Mar 8, 2011 | 04:26 AM
fcluddington's Avatar
are you talking if you mash the gas pedal to the floor vs bringing the rpms up slow does it do it both.
Old Mar 8, 2011 | 05:55 AM
fcm's Avatar
fcm
Old Fart
What is the fuel pressure, have you changed the fuel filter? 94
Old Mar 8, 2011 | 07:46 AM
::ek-4::'s Avatar
Check your grounds and your coil. Have you tried using a friend's dizzy to make sure it's not that?
Old Mar 8, 2011 | 07:53 AM
JRSC_EK's Avatar
Maybe a valve adjustment?
Old Mar 8, 2011 | 11:09 AM
DumpdEJ6's Avatar
I like the tuna here
I had a similar problem with my B16A, in my case it was plug wires.
Old Mar 8, 2011 | 11:27 AM
Necromonger's Avatar
I would begin by testing your spark plugs, then the wires. Check for any resistance in the wires or continuity. If that does not find the culprit begin to check the distributor, check to see the rotor is find then inspect the vacuum advance and the centrifugal weights and see if they are springing out.
After that passes, then start checking other electrical components like your ignition coil see if it is collapsing right or discharging right. Could also be the AC generator not feeding the primary ignition the required voltage to jump the voltage in the ignition coil. This can go on and on LOL
Best thing to do is check the source, which is your secondary ignition system first then go through all the trouble shooting through the primary and other electrical systems and components.
Nick Cronk
Apr 20, 2013 06:14 PM
milanocivic
Feb 20, 2009 08:26 PM
98coupe
Aug 30, 2005 05:22 PM
90SiHatchbk
May 9, 2004 12:04 PM
94civicsally
15
Mar 18, 2004 09:50 AM
