**BRAKE GURUS... Enter here**
Hey guys, I have a question that hopefully someone can help me out with. I know there is a brake forum, but there are about 10 posts and no one reads it so that's useless.
I'm in need of replacement calipers for my rear brakes. I need something that will fit a 98-01 ITR 5 lug brake knuckle/rotor, that is NOT an ITR caliper. Reason being, the company that is supplying me with re-built OEM calipers does not offer ITR fitment because they are rare to come by. SO, I need an application that is more common, if such a thing exists.
Are there any other fitments i.e. Prelude, CRV, Legend, etc that will bolt on directly and work with ITR REAR pads/rotors/knuckle?
Thanks!
NH
Thanks!
NH
EP3 calipers will work IIRC but you have to swap them from left to right.
Btw, have you considered rebuilding the ITR calipers? This is one of those rare cases where it might be worth it.
thanks for the info, I will see if it's an option to send in my own calipers for rebuilding. anyone able to confirm the EP3/DC5 option?
honestly this is one rare occasion that i would say post or move this topic to the itr forum. those guys know more than honda about their own cars
I know there's a sponsor in the brakes/suspension forum that sells re manufactured OEM brakes. Might not be a bad idea to PM him and see if they offer a rebuild service.
They do, but that was for first gens, and front calipers, all first gen CR-Vs had rear drums unfortunately. Second gens I can't remember if they look the same or not, third gens are totally different.
Only the DC5 / EP3 calipers would be a substitute, however as stated you would need to swap the calipers left to right or vice versa. Other calipers (from the Accord, CR-V etc.) are similar in caliper body design and would "bolt on" but the parking mechanism is not capatible, hence why only ITR calipers and / or EP3 / DC5 calipers are interchangeable (because the parking brake systems are similar in function).
I would also recommend a rebuild of the caliper. You can get basically everything new, except the caliper body. I highly doubt the caliper body is in need of repair.
I spoke with Centric, and they will re-build my calipers if I send them in, so that's most likely what I will do. the turn around is supposed to be about 2 weeks so I'll have to wait until after the 18th (open test @ Buttonwillow)
Corksil
Nov 8, 2011 09:08 AM
