swapping out struts question
Old Mar 7, 2011 | 10:04 AM
724chris's Avatar
Default swapping out struts question
ok my question is with the front struts on a eg. do i have to seperate the upper ball joint to get it off or can i just unbolt the fork then take the fork off the strut to get it out? i want to know before i start so i can get the balljoint seperator.thanks
Old Mar 7, 2011 | 10:10 AM
grumblemarc's Avatar
The Grumpiest
Default Re: swapping out struts question
You shouldn't have to touch any ball joints to swap out struts. If you do you're doing it wrong.
Old Mar 7, 2011 | 10:13 AM
PardonmyEK9's Avatar
just have a buddy step and put slight pressure on the disc then slip her out
Old Mar 7, 2011 | 10:39 AM
724chris's Avatar
iight cool. and for the backs what is it easier to unbolt the lca from the subframe or the trailing arm?
Old Mar 7, 2011 | 11:20 AM
The Grumpiest
Why are you unbolting the LCAs?
Old Mar 7, 2011 | 12:42 PM
again just unbolt the strut from the LCA and from the top but slight pressure on the brakes. she should pop out. plus the Lca bolt to the subframe is a B*tch most of the time
F&Facuracl
Apr 1, 2012 05:43 AM
s13hero
Aug 18, 2009 11:23 PM
ifIexplode
Dec 8, 2008 06:08 AM
my95civic
Jul 31, 2004 08:43 AM
