Vtec not working pls help!
Hey,
Wassup guys i have a 92 Gsr B17A1 after i change out the oil pan yesterday Vtec is not cracking no more. I pulled out the ecu fuse and plug it back in then vtec cracks but going to work this morning tried punching it and vtec is not working again. Any idea of what my problem is?
Thanks In Advance!
Thanks In Advance!
my guess is you drained everything before you pulled the pan so its gonna need around 5 qts of oil so check the oil level! then clean out the vtec solinoid with carb cleaner and replace the gaskets while your at it it might be cloging.
Alright ill give that a try when i get off work today. Thanks for the reply!
ok went home yesterday checked the oil. Oil level seems to be good so i unplug the ecu and plug it back in then wham vtec works. But then let it warmed up this morning driving for 20 mins to work no vtec but when im makin a right turn to my work block i tried it and vtec is working again. any ideas why this is happening?
Hey im a newbie but i had a question and cant post a thread yet. I'm no mechanic but i was wondering if anyone knows why my VTEC is not working. My friend just helped me swap a JDM B18C ITR Motor 97 spec swap with JDM ITR ECU into my 94 GSR but i keep getting an engine check light. My friend said that because of the engine check light going on, this is why my VTEC doesnt work. We cant figure out why the engine check light goes on and or why VTEC doesnt work. The engine check light does not come on when the car is started but then it turns on once i start driving. Can anyone help or give me any troubleshooting tips? thanks!
Yup!
You changed the oil, you probably didn't put enough in. Just think about the problem here, everything worked, then you said you just changed the oil, then everything didn't work.... See where I'm going with this?
There is also a sticky which will help you troubleshoot this, please refer to that first!
