fresh, rebuilt D15B engine. What oil should I run?
Old Mar 7, 2011 | 04:48 AM
r.etheridge's Avatar
Default fresh, rebuilt D15B engine. What oil should I run?
I just rebuilt my D15B8 engine( rings, bearings main caps and rods, valves and seals, ect) and im not sure if I can start off running amsoil which is full syn oil or do I need to run regular oil for a few thousand miles first. any info would be great. Please do not post unless your 100% sure, cant afford to mess this engine up. its my DD and I used all oem honda parts for the rebuild so it wasnt cheap. Thanks
Old Mar 7, 2011 | 06:08 AM
Cynical 1's Avatar
Default Re: fresh, rebuilt D15B engine. What oil should I run?
i'd use a good quality conventional oil until the first oil change. something like valvoline or mobil.
then go synthetic...
others may have different ideas, but this is what i do.
Old Mar 7, 2011 | 07:53 AM
NotAJDMFanBoy's Avatar
normally people run regular straight 30 weight to start it up, then drop the oil because during the initial start up you end up with bearing material, shavings off rings, any foreign debris from machining that wasn't cleaned well enough.
Use a quality conventional until it's well broken in. The conventional allows the rings to seat correctly.
After it's broken in, you can run synthetic.
The majority of the breaking occurs in the first 20 miles. There's conflicting information about how to break a motor in but the main two views are running it easy, believing you can't be hard on a new motor or it'll ruin it. Or you have to get on it to force the rings out against the walls to break in and do multiple cycles of accelerating and letting the engine brake itself. The key is not romping on the motor, just putting a load on it.
Old Mar 7, 2011 | 08:43 AM
cool, thanks for the info guys
Old Mar 7, 2011 | 11:44 AM
delsizzle1's Avatar
i agree whenever ive had to rebuild and or put back together a motor after some much needed work.. even the dealer specifies to break in the motor for about 500 with conventional 5w-30 oil... sometimes even 10w-30... and after since the motor will be fresh use a part synthetic in it.. really no need to use full synthetic unless u plan on building it to certain specs that may need for it... at least those are my opinions
Old Mar 8, 2011 | 02:20 PM
milkwasabadidea's Avatar
on my rebuild i used reg 5 30 for first 3k miles then synthetic after
Old Jul 3, 2014 | 05:25 AM
ahmad77084's Avatar
Default 1996 civic rebuild engine
My mechanic used synthetic oil at the first start up and I've been running about 150 to 200 miles on the first oil? I need help to not loosing my engine
Old Jul 3, 2014 | 05:30 AM
ahmad77084's Avatar
My mechanic used synthetic oil at the first time in starting up the engine and I've been running around 150 to 200 miles on the first oil. I need help to loose my engine?
Old Jul 3, 2014 | 07:43 AM
tony_2018's Avatar
Fish Twig
You need help to do what with your engine?
Old Jul 3, 2014 | 09:34 AM
W95civicEXcoupe's Avatar
GDD's Resident Derp
LOL
I think he is saying with very bad English that he "does not want to lose his engine," or "needs help not losing his engine" and I assume that means breaking or damaging it.
Old Jul 3, 2014 | 09:55 AM
grumblemarc's Avatar
The Grumpiest
Then follow the break-in procedures. Or is that what is in question?
Old Jul 3, 2014 | 10:12 AM
shotoutacc0rd's Avatar
Use some actual break in oil?
Old Jul 3, 2014 | 10:28 AM
NotARaCist's Avatar
I never narc'd on nobody!
Break-in oil, with a high zinc content. Start the car, let it warm up, check for leaks. Once it warms up, drain and refill again with fresh break-in oil. Run the engine hard for 50 miles. High load pulls and engine braking. Drain and refill one more time with fresh break-in oil. Drive normally for 500 miles. Drain and refill with whatever oil you want, and continue standard oil change rotations from there.
While you're at it, don't bump 3 year old threads.
Old Jul 3, 2014 | 12:05 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 1996 civic rebuild engine
What is done is done, the power loss is already there and there won't be much improvement now doing the proper break in procedure. Your motor will be in need of a re-ring job and solid hone in 1-3 years instead of say 3-5. Times vary from person to person and situation to situation.
What is known is much life has been removed from your motor due to faulty break in on the fresh rebuilt motor. Can't take back those 150-200 miles.
x2 about not bumping 3 year old threads.
Old Jul 13, 2014 | 05:51 PM
hondahatch22's Avatar
I got a problem well idk wat to do.. I just rebuild my b16a and it burns oil.. it has new piston rings ,oil pump, etc.. well I just fired it nd it works just great, but then a couple of hours later white smoke came out from the exhaust.. nd it smells like oil.. I ran it for about 120 already nd still smock coming out from the exhaust
Old Jul 13, 2014 | 05:53 PM
NotARaCist's Avatar
First off, stop bumping ancient threads. No one likes that guy. Don't be that guy.
Second off, did you even TRY to read this thread? I can already tell that you didn't. Either you fucked up your rebuild with incorrect clearances, gaps, and decking, or you fucked up your engine by not breaking it in correctly.
down_the_hatch
Dec 6, 2015 09:59 PM
purplerain11
Jul 6, 2012 06:42 PM
killerpenguin21
18
Mar 11, 2008 09:25 PM
FERIOkid
May 22, 2005 02:44 PM
se93
Nov 16, 2001 06:06 PM
