2002 Accord SE
Old Mar 6, 2011 | 04:44 PM
DannyMcK's Avatar
Default 2002 Accord SE
Finally got around to replacing the stock CD/tape deck in my 2002 Accord SE. One of the wires coming off of the new wire harness was an orange/white wire labeled Dimming. The new aftermarket deck didn't have a corresponding wire to connect to, so I decided to connect this to the 'illumination' wire on the new deck.
I didn't realize until after finishing the install, and driving at night, that the dash lights no longer come on. I just checked again, and found that the tail lights are no longer funtioning either. I checked fuses, and didn't notice that any are burnt out. There is a space under the hood fuse box labeled "dimming relay", but it is a blank space. There is another 'space' in the fuse box under the dash for 'day light', also blank. I checked several other fuses, didn't see any blown fuses.
I have since disconnected the dimming lead from the wire harness so that it is not connected to anything.
Did I blow a fuse that I just haven't seen, or did something else get shorted out? Or do I need to connect the dimming lead to something? Any suggestions are greatly appreciated!
Old Mar 7, 2011 | 12:33 PM
accordcrv's Avatar
Default Re: 2002 Accord SE
i have a similar problem to yours except its just the dash lights that wont come on and now my engine wont turn over. i searched it on the internet and i think that it may be that the multiplex on the drivers side has malfunctioned
Old Mar 7, 2011 | 07:36 PM
DannyMcK's Avatar
Yikes, that sounds a little more serious than mine; my car hasn't had any issues with starting.
I've read that if a tail lights goes out, that the dash lights will go out until the tail light bulb is replaced. This is so the driver knows that a lamp is out. I haven't checked my tail light bulbs, but I don't know how I would have burnt one out just by replacing the stereo.....
Any suggestions are greatly appreciated!!!
vtak2nr
Audio / Security / Video
Sep 8, 2011 08:02 PM
amjam123
Jul 3, 2008 10:52 AM
eric416
Jun 28, 2006 04:14 PM
ogdogg16
Jan 14, 2003 09:39 PM
HatchBox
13
Aug 7, 2002 10:40 AM
