Help Getting O2 Sensor Off
Old Mar 6, 2011 | 03:52 PM
TonyRomo's Avatar
Default Help Getting O2 Sensor Off
I can't get my upstream O2 sensor off.
I sprayed it with PB Blaster like three days in a row and put a wrench on it and hit the wrench with a hammer. Nothing works
Any tips???
Old Mar 6, 2011 | 04:36 PM
1998GsRIntegra's Avatar
Default Re: Help Getting O2 Sensor Off
O2 Sensor socket.
or
Run the car hard, get it up on jack stands and try to get it out while the car is still hot.
Old Mar 6, 2011 | 09:22 PM
94VTEC2TONE's Avatar
im not a fan of 02 sensor sockets myself. I took mine off with a 21mm wrench and a hammer, beat the **** out of it, it works, mine didnt fit as tite as i like so be careful not to round **** off if its not snug
Old Mar 7, 2011 | 08:21 PM
Naiyasin's Avatar
Breaker bar. Piggy back two wrenches. WATCH YOUR KNUCKS.
Old Mar 7, 2011 | 08:25 PM
Surge11's Avatar
You probably need to heat it up before taking it off. If you can, borrow a blow torch.
Old Mar 8, 2011 | 05:05 AM
Murk 'EM's Avatar
Yeah use a touch preferably map gas get the bung glowing red then use an o2 socket and a breaker bar it'll come off
Old Mar 8, 2011 | 05:39 AM
N/A's Avatar
N/A
Purpose Built
Assuming the o2 you are taking out is bad...
Id cut the wires right off of it and get a socket on it with an impact gun
Assuming it is good...
If you have access to a torch, turn the bung cherry and it'll. Come out with whatever has a tight grip and leverage
If you don't have access to a torch, drive you car a while and get on it real good right before you stop to take the o2 out
If those don't work just cut the wires, impact it off and get a new o2
Old Mar 8, 2011 | 09:10 AM
vrrodri's Avatar
Take the pipe off the car, use airgun with socket from above, it will come off right away.
Old Mar 8, 2011 | 09:50 AM
94preludeguy's Avatar
Some of you guys are foolish. All you need is a propane torch and o2 sensor socket. Both are pretty cheap tools that will go a long way. (I've used my propane torch and o2 socket countless times over the past 6 years) I don't think I've ever had an issue with an o2 sensor using a torch and socket. However any other way I've tried when I didn't have a torch or anything I had a hell of a time.
Old Mar 8, 2011 | 09:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
O2 sensor sockets usually have a hex head on the back end of them. I used the O2 sensor socket and then a very short, quick burst of the impact on that O2 socket's hex head. I think most of them are 21mm. Worked like a charm.
Old Mar 8, 2011 | 11:14 AM
vrrodri's Avatar
^^^ Exactly....
Old Mar 8, 2011 | 11:42 AM
N/A's Avatar
N/A
Purpose Built
Who's foolish? I haven't seen one bad suggestion why u gotta come in insulting?
ajholt7
Jul 31, 2011 06:31 PM
joe.wong321
10
Feb 22, 2008 11:41 AM
shbrown
Mar 1, 2006 02:58 PM
boostinh22
Dec 8, 2005 11:33 PM
Sir_Phobos
Feb 15, 2003 10:55 AM
