94 civic: hazard, horn and brake light problem..possible connection?
If this is a repost. Im sorry I did look but nothing similar came up. I have a 94 civic I just picked up and everything was workin fine now I noticed the other day my hazzardsand horn were not workin so I figured a fuse and decided to look at it later. Till I noticed that the breaklights whouldnt turn on I mean my head lights were on as well and the taillight but when the break is pressed the brake lights will not go on or brightin up instef there just lit up like I didn't brake even the third breaklight does not go off so my question is it possible for these to be connected somehow? How can i get it fixed? The fuses I checked are not popped unless im lookin at the wrong fuse which I doubt but u never kno any helps greatly appreciated
Where 46 and 45 is,the diagraM I looked at showed 42 and 43. Being there but this dosent sshow me where they are... I must've looked at 96 and up and the test I did showed the light fully glowing...I need to do a voltage test so ill have to do it again tonight
Test for voltage at BOTH top test tabs of each fuse.
ok i tested it on a digital multimeter just now and im getting a zero reading for both im goin to autozone to see if they can test it if anything a friend has a fuse box we might swap to see if its the box whitch i doubt but hopefully will work ill let u kno when i get the other reading before i do anything else
Ok I tested voltage and its reading about 41 for each tab so I guess its getting voltage what's the next step for me
41 volts? Should be about 12.5 volts to body ground at each tab. It's unlikely you are testing voltage correctly. Did you click the Test Fuses link and read the method for how to measure voltage?
ok ihad the test redone but they did the light test and it glows for both tabs on the top of the fuse and i had done another voltage test which idk how to do and no one seems to kno to use at the auto store or radioshack but it came up between a 5 and 6 if that makes sense but i did do the method shown in ur signature
Ok I believe I did it right this time it was reading012 for each tab so does this mean its possibly something else?
Describe how you did this test and what multimeter setting was used. Post pictures.
The multimeter setting was dcv 20 and I put the car to on postion thenground at ground and the fuse on top of the tabs but it didn't read for me I did it again today and it popped the fuse the positive prong sparked and the ground was sparkin when I put to the bolt head I wad grounding I can take a picture for u later tonight? Is my fuse box wired wrong u think?
im using this multimeter
