Questions about full 98 integra brake swap into 93 hatch
i know there is alot of info out there on doing the full 98integra brake swap into my 93EG coupe, the Few questions i still have remaining is
what Year/Model, should i get the master Cylinder, and PPV from for a straight drop swap, with no mod,
i know that i cannot use either of these if the car came with ABS, so which model did not come with ABS.
did any 92-95 civic ever come with rear disc brakes and ni ABS.
thanks for any help here, i have allready searched
91 Civic EX master cylinder 15/16 and no abs
92-93 Civic Si came with rear disc and no ABS, 94-95 Civic Si had the option of ABS, but not all came with ABS...IIRC
I have no experience with other models, so maybe somebody else can chime in with other models you can salvage parts from.
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please familiarize yourself with the stickies at the top.
Because you are a new member, I edited the title for you this time.
Front and rear brakes can come from any '94 - '01 Integra (except ITR, unless you want to run 5 lug) proportioning valve needs to come from a '94 - '97 Non ABS integra (RS model) Same goes for the brake booster and master cylinder, or you can use a master cylinder from a '90 - '91 Civic EX and keep the stock booster.
Suspension & Brakes
10
May 23, 2009 06:50 AM
saber1
Nov 11, 2002 11:09 PM
