91 hatch alarm problem! need help asap :(
Old Mar 5, 2011 | 11:16 AM
JDanyM's Avatar
Default 91 hatch alarm problem! need help asap :(
So here's the deal, last night my remote to turn on and off my alarm ( the keychain on) was lost!! And I thought with the key I would be able to deactivate the alarm but that wasent the case. Since the car already came with the alarm when I bought it I don't know where the switch to turn off the alarm is in the car!! So I'm preety much stranded in a parking lot not able to move my car anywhere right now! So if you guys have ANY ideas of what I can do please let me know! Thank you
Old Mar 6, 2011 | 10:44 AM
fcm's Avatar
fcm
Old Fart
Default Re: 91 hatch alarm problem! need help asap :(
Start by disconnecting the cars batt., [neg.(-) terminal], stick your head up under the drivers side of dash and see if you can find the alarm brain or the valet/program switch,
If you find the alarm brain, unplug it, and see if car will start, get a make and model of alarm.
If you find the switch, reconnect batt., [alarm should trigger] turn ign. key on and press and hold switch until alarm turns off, [may take a few sec., depends on alarm], if alarm does not disarm with switch you will have to find the alarm brain and unplug it and if car will still not start I need a make and model of alarm, there may be an ign./starter kill either built into alarm brain or wired as N/O, [normally open] and it would have to be "jumped".
Question, does engine crank but not start or not even crank? 94
lickety_britches
Audio / Security / Video
Nov 27, 2008 09:07 PM
type B16
Jan 8, 2007 04:49 PM
iNetForce
May 31, 2004 09:25 PM
faiz_23
Mar 13, 2002 06:38 AM
JL 74
12
Jan 9, 2002 09:48 AM
