Right way to install traction bars?
Old Mar 5, 2011 | 09:37 AM
LightningTeg's Avatar
Community Builder
Default Right way to install traction bars?
Hey I have a set of full Race bars, and I've noticed my passenger side radius arm length is a bit shorter then the driver side. Only one of the radius arms will even get short enough to fit leaving very little turning left to preload.
I've also had to clock the mounting brackets on the control arm slightly inward otherwise the bolts included will run into the shock forks. Is this normal? The best I could do was put the brackets on when the car is on the ground and then lift it to attach everything else.
Am I missing something here?
Old Mar 5, 2011 | 09:42 AM
rotoactivo2's Avatar
Default Re: Right way to install traction bars?
In my opinion the best way to do this is to install them and get an alignment done. Since intalling them changes the caster measurement along with the toe and sometimes even camber. GL hope this helped
Old Mar 5, 2011 | 09:44 AM
Community Builder
Well I mean its not so much the alignment. Just getting them to fit "correctly" in the first place
Old Mar 5, 2011 | 10:43 AM
PaulPero's Avatar
Sounds like the car was hit
Old Mar 5, 2011 | 11:29 AM
Community Builder
Yeah the car was in a front end wreck a few years ago. I assumed this was probably the main issue . Doesn't explain how to mount those brackets though.
For a street car its desirable to have the preload "pulling" the suspension forward?
Old Mar 5, 2011 | 11:58 AM
PaulPero's Avatar
For street i would put the car down on the wheels and turn the bars till there neutral then pull the control arms just a turn or so foward. If you look at the control arm horizontaly then the tabs should be horizontal also.
Old Mar 5, 2011 | 05:04 PM
Community Builder
I guess you supposed to take the shock fork bolt out and move it? I feel stupid lol
taylorgang
Suspension & Brakes
Apr 4, 2012 12:03 PM
4drEF
36
Mar 26, 2007 06:39 PM
Fooser
Mar 28, 2002 07:59 AM
96whitels
Feb 1, 2002 07:12 PM
CLICC916
Jan 28, 2002 01:02 PM
