Vafc 1 possible to install with VTEC E
is it possible to install the apexi VAFC 1 it for the VTEC E sock vx motor?
i don't know if vtec e is listed in the instructions booklet ecu and model.
^True the d15z1 already has no horse and gets great gas.
If you have a W.B. and are trying to get even better than yes it is doable. You set it up the same as any D series I believe. I take it you are talking about setting it on the screen with the cylinders and the arrow?
http://www.scribd.com/doc/12609731/Apexi-vAfc-Manual
i just want to install it for monitoring and see if it works i got it for Christmas. i don't want to tweak anything with the vtec. i just wanted to know if it is still compatible, bc the instructions don't have the ecu and model for the vx? and its vtec e. if installed does it automatically changes the vtec points i don't want to change but leave it oem.
