b20b swap into 93 integra
If it wont ever turn over then your not getting power to something. Start with the ground and power wire to the starter, the fuses, make sure your ignition switch is hooked up correctly.
check fuel, spark, and timing, electrical fail somewhere if that stuff checks out fine, hopefully your integra ain't all hacked up and **** on the cabin or engine harness.
