wtb: B series hydro trans
I have a hydro b16 trans, gears are fine. Needs new mainshaft bearing. Had the "whine" noise while cruising. Can replace the bearing or sell without replacing.
Matt - 540-336-1684
Edit: It should be the bearing just behind the main shaft, the one that sits in the casing, not one that has to be pressed on/off. Had to do that to my previous transmission, bearing is about $30 or less from honda.
Matt - 540-336-1684
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
How much
Matt - 540-336-1684
Matt - 540-336-1684
if you want to drive to glen burnie i will be around all afternoon/evening
i brought the trans home from work hoping to meet up and i dont want to be hauling it around
