hondata s300 and id 1000CC
my buddy got a base tune with his hondata s300 system, the car floods hardcore when trying to start on cold motor? like needs new plugs in order to run.. how can he adjust the injectors not to flood on cold start startup... hes got id 1000cc dead times set for 45 psi fuel pressure..
thanks in advance..
thanks in advance..
The overall fuel trim is crazy.
Try lowering that value to something like 15-20 and go from there.
It is rather pointless to see this and not the fuel map also, so your best bet is to have someone come tune the car.
hopefully after tune the car doesnt have this issue... my buddy ran some 750cc p and h injectors and drove home an hour.. next morning.. the car was flooooooded hardcore.. need new plugs to start..
As mentioned above, your fuel trims are all wacky :-)
Reducing crank fuel will help,
but if you want to do it right,
the "Current Injector Size" should be around 895cc, then your over all fuel trim will be alot closer to 0 and everything else will fall into place little neater. You'll probaly have to have the fuel maps dialed back in..
please explain? i have id 1000cc why set for 895?
then where can i read reasoning, would like to pass this info on to tuner... i love it u guys are like bakers that don't wanta give away ur secret ingredient.... lol, wish hondata had a nice video tutorial like crome and neptune so on youtube.. one one of u guys make a "omniman 200 whp b16" style video.. tuning a turbo honda.. lol ill volunteer my car..
Because Burgermass thinks that when you flow injectors with test fluid instead of gas that means you are supposed to put 895cc in Hondata...
Do I win a prize
And watch out, another tuner on Honda-tech told me if I idle my car at 11s that I will wash my rings!
Do I win a prize
