Eg power window conversion ????
Old Mar 3, 2011 | 10:29 PM
eg-6 life's Avatar
Default Eg power window conversion ????
Hey Honda tech i been doing reserch about putting power windows on my 93 civic si
I put the complete doors from a civic ex n I was just gonna wire them up to the fuse box
But some one told me to just get the floor harness form an civic ex
But idk if its just plug n play since there amost the same
has any one done this b4 I don't want to cut or build a harness I wanna know If
I take the harness off n put it on the hatch n it will plug n play
If so do u have links pics or something
Please help
Bump if view
Old Mar 3, 2011 | 10:55 PM
kyosoeg6's Avatar
Default Re: Eg power window conversion ????
im only bumping this thread cause im posting a reply. you people really need to do a search. its like doing ****ing homework. you cant just ask for the answers. i personally have made a thread about my personal power window conversion.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-95-civic-power-door-conversion-right-way-tons-pics-end-all-swap-2337026/
if youve already got the doors on then this is all youll need to hookup and saas, youll have full working power windows and door locks in your hatch
Old Mar 3, 2011 | 11:02 PM
eg-6 life's Avatar
I saw ur thread read everything but if u read I put on top I don't wanna cut or do all that my question was would it work if I just take the inside harness from the ex n put it on the hatch will it work
Old Mar 3, 2011 | 11:18 PM
kyosoeg6's Avatar
are you seriously gonna take out the dash just to install this power harness? the power accessory harness is a completely separate wiring harness from teh main one.
Old Mar 4, 2011 | 06:25 AM
eg-6 life's Avatar
So is not worth it so what harness do I need from the ex then
Old Mar 4, 2011 | 06:27 AM
94EG8's Avatar
Seagull Management
It's all one harness, you can pull apart an EX harness and make a seperate harness if you want though.
Old Mar 4, 2011 | 06:45 AM
weavertime1's Avatar
That's not actually true.
Old Mar 4, 2011 | 07:09 AM
eg-6 life's Avatar
^^so why I asked in the first place will work if I pull the complete harness from the ex coupe n put it on my si hatch
Old Mar 4, 2011 | 07:22 AM
94EG8's Avatar
Seagull Management
Yes that will work fine. Make sure it comes from a 5 speed if you have a 5 speed.
Old Mar 4, 2011 | 07:31 AM
eg-6 life's Avatar
^^yea there both 5 speed
^^so that harness is the one that goes from
Firewall to fuse Box to both doors to ecu
To fuse box inside to main relay to sunroof
That's the one I need to get right
Old Mar 4, 2011 | 07:32 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Be prepared for an arduous task, though, OP. It's not a walk in the park. Also you will need to add wiring for your rear wiper/washer if you have one and still want it to work.
Old Mar 4, 2011 | 07:36 AM
eg-6 life's Avatar
^^ but isn't that a separate harness that's the one that goes to the ignition to the fuse Box
Old Mar 4, 2011 | 07:41 AM
deschlong's Avatar
Loved
Community Favorite
It actually goes from your P/S headlight to firewall to ecu to p/s door and across to fuse box and d/s door and to steering column & combination switches. I've pulled a couple, I know. Moonroof harness is separate.
Old Mar 4, 2011 | 07:44 AM
94EG8's Avatar
Seagull Management
Exactly. I've also pulled a few of them. It's time consuming, and require pulling large portions of your car apart. But it's not particularly hard, just time consuming.
Old Mar 4, 2011 | 07:56 AM
eg-6 life's Avatar
Thanks guys
Old Mar 4, 2011 | 08:16 AM
kyosoeg6's Avatar
by the way hes stating his replies, hes making it seem like he doesnt even want to separate the power harness from the ex main dash harness. thats why i replied with what i did.
to the op: your making it a lot harder than it really has to be. just get yourselft an ex main dash harness, separate the power harness from the main dash harness using the step by step picture included link i posted on here and be sure to get the driver side pigtail that plugs to the fuse box and also connects to the passenger side pigtail. at the end of the day you should have some thing that looks like this
if you look at the pic, the big fat black plugs are the plugs for each door, the big grey plug in the middle of the pic thats kind of hiding under part of the harness is where the driver and passenger harness plug into eachother. the pale green plug just above that is what connects to the back of the fuse box.
if you need any more help with this just ask but youre turning something simple into a big ol task. ive done this swap at least 6 times in the past year and a half because once everybody saw my hatch with the pd/pw/pl they all wanted it too.
Old Mar 4, 2011 | 08:55 AM
eg-6 life's Avatar
Idk what to do lol I know this one guy that just connect them to the fuse box with his owen wires does that work good too or should I just go with the short harness or the complete harness
Old Mar 4, 2011 | 09:05 AM
DCRB's Avatar
omfg just seperate the wiring for the power options from the stock ex harness like kyosoeg6 said to do. that way you have the least likelyhood of gremlims down the road as apposed to just ghetto hacking it. i did this conversion in my hatch n just made a seperate harness for the windows and mirrors and everything works great.
Old Mar 4, 2011 | 09:56 AM
eg-6 life's Avatar
Ok but I still need to pull the complete harness n then split it then
Old Mar 4, 2011 | 11:17 AM
eg-6 life's Avatar
Does any one near la know how to do it if so how much n when can u do it
Old Mar 4, 2011 | 07:25 PM
eg-6 life's Avatar
Ima go with what"kyosoeg6" did on his I looked at it over n over I or it it's the easy way thanks I'll post later when I finish to c if it worked
Old Mar 12, 2011 | 04:15 PM
eg-6 life's Avatar
Thanks a lot "kyosoeg6" I did it the way u told me to
And it works perfect took me like 2-3 hours to strip
A car at the junk yard but I did it n the best part was I only payed
$10 for the harness n antena that I need it thanks
A lot bro
Old Jul 9, 2012 | 11:05 AM
stevieleeeg6's Avatar
hey eg-6 life do u think you can help me out with mine?
Old Jul 9, 2012 | 05:25 PM
Former User's Avatar
This is an old thread. Please check the FAQs sticky and make your own thread when you formulate specific questions.
IGotVTECyo
Oct 9, 2006 07:38 PM
JDM*addiction
Jun 26, 2005 11:00 AM
ricearoni56
Apr 2, 2004 11:48 PM
