b16 blowing oil
Old Mar 3, 2011 | 10:21 PM
bradabu's Avatar
Default b16 blowing oil
i have a b16 and today i put a new head gasket on and it started blowing oil out when i started it from under the intake manifold. its shooting out and im not sure where its coming from. anyone?
Old Mar 3, 2011 | 11:18 PM
EFPhilly's Avatar
Default Re: b16 blowing oil
Get some brake cleaner and get to cleaning it and then start the car and look for the leak. If its by the HG have fun doing the job right the 2nd time
Old Mar 4, 2011 | 12:26 AM
mphirephox's Avatar
if its in the back in between the #3 and #2 there is a small plug under the intake manifold, my head guy took this out and didn't replace it on a head i got remaned. did you have the head done? or just a replacement head gasket?
Old Mar 4, 2011 | 12:46 AM
bradabu's Avatar
i took my head to get resurfaced
Old Mar 4, 2011 | 12:49 AM
mphirephox's Avatar
Take off the intake and look in between the #2 #3 runners on the head there's a small hole that needs a plug. See if its there.
Old Mar 4, 2011 | 09:53 AM
EFPhilly's Avatar
^nice. Assuming he had the motor running before I thought, hm you only change one variable dont know if the machine shop would have taken out the plug....but its good to check.
Was the motor running fine before no leaks, or is this a first start. You said replaced headgasket so I assumed you had to B16 running prior, and its not LSV right?
Old Mar 4, 2011 | 10:54 AM
bradabu's Avatar
yes, the motor was running fine before, with no oil leaks
Old Mar 4, 2011 | 12:47 PM
civicsirebuild's Avatar
man, i hate to ask, but only cause ive done it... are you sure the HG is on right side up...mine did the exact same thing with it upsidedown
Old Mar 4, 2011 | 07:27 PM
mphirephox's Avatar
Head bolts replaced or reused? ARP studs? If they are reused they may have stretched (ARP wont matter). Please let us know what the end result is when you figure it out.
Old Mar 4, 2011 | 07:34 PM
hybrid1990crx's Avatar
I agree. I did this on the 3rd head gasket I did lol. But it puked oil out from the front of the head.
Old Mar 4, 2011 | 11:30 PM
EFPhilly's Avatar
I think the OP replaced his headgasket due to overheating (my guess...btw you should say more information) and warped the head. Did you run the car with it overheating for a long time? If not my guess would be upside down or faulty gasket (which is rare). Felpro even has it down! What gasket are you running Auto-place or OEM gasket?
Old Mar 4, 2011 | 11:31 PM
EFPhilly's Avatar
This should help:
How to on how to install a headgasket, make sure you did the steps right:
http://www.clubintegra.com/board/showthread.php?t=56129
Old Mar 5, 2011 | 04:34 PM
-__-'s Avatar
bingo. he said he re-installed it and now its fine. he put it in the wrong way LOL!
Old Mar 5, 2011 | 04:37 PM
EFPhilly's Avatar
^ thanks for the update. Another score for HT!
Old Mar 5, 2011 | 05:17 PM
-__-'s Avatar
^^yeah thanks a lot for contributing. pretty much diagnosed a car over the internet haha. THIS is why i contribute to HT.
flushsi
Jun 29, 2011 04:59 AM
strsi
Apr 6, 2005 05:28 PM
Cashflo
Mar 30, 2003 11:47 PM
