Do i need a relay for my kill switch?
Old Mar 3, 2011 | 07:32 PM
sintek209's Avatar
Default Do i need a relay for my kill switch?
I have a 14 gauge wire cut into the ground wire on the clutch interlock switch, which runs to my kill switch grounded to the frame. Do i need to put a relay in? What about a fuse holder?
Old Mar 3, 2011 | 09:12 PM
Linked's Avatar
Default Re: Do i need a relay for my kill switch?
from what i believe, the starting circuit already has protection (fuse) and you could use a killswitch directly inline with the clutch interlock, given that you use a lower gauge wire (6 maybe 8? idk) and a killswitch capable of handling high amperage
the route of using a relay to control it works as well but IMO is more of a hassle with wiring
but how it'd work is:
pink wire going towards clutch switch = terminal 30 of relay
other end of that pink wire = terminal 87A i think of relay
now the load side of the relay should be inline before the clutch switch
12v positive = terminal 85
ground to chassis = terminal 86
the killswitch and fuse (idk rating) could be on either 12v positive of ground side of the relay
Old Mar 3, 2011 | 11:40 PM
sintek209's Avatar
Why would i want to use such a low gauge wire? I understand that it would have more resistance, but current is flowing to the ground (frame of car) in one direction. Whats the problem of using a 22 gauge wire (the same gauge as the ground wire from the interlock switch) to my kill switch (30amp rating)?
I'm still learning electrical theory
Old Mar 4, 2011 | 12:23 AM
mphirephox's Avatar
I wouldn't use the clutch cancel as a means of a kill switch personally. I would use ignition kill or fuel pump cut. Just my 2 cents
Old Mar 4, 2011 | 08:32 AM
hondamark35's Avatar
right, for a safety kill switch. i would run a kill circuit w/ two relays to cut both ignition and fuel pump with one switch.
however if you're just trying to add another level to a "theft deterent switch" setup the clutch interlock isn't a bad idea. i used to have one on my last civic. no need for relays, used the same gage wire that the interlock switch uses (16..18?) and never had issues.
Old Mar 4, 2011 | 08:54 AM
SiRCiviC94's Avatar
I did not, it is always good to use a relay and a fuse. esp if the wire is longer than a few feet
Mike M
Oct 2, 2014 02:19 AM
Joon Joon
27
Oct 23, 2005 05:49 PM
integra99blue
Aug 16, 2001 09:49 PM
