NO POWER TO INJECTORS --NEED HELP--
Old Mar 3, 2011 | 05:15 PM
DC2R96's Avatar
Default NO POWER TO INJECTORS --NEED HELP--
Have fuel pressure and spark and no pulse I checked with Noid light ... Replaced my main relay that didn't help .. the only code that my car is throwing is a ECT (code 6) .. is there something I should check on my ECU connections .. I got my harness from Rywire so I'm pretty sure that's OK .. Is there a fuel injector relay besides the main relay?? that's what it seems like to me ...
I moved some ground wires and now have power and ground to my injectors but when I turn the motor over still no pulse .. what makes the injectors pulse the computer? How can I check to see if that is the problem ? cause I have plunty of spark no problem there just no pulse .. wouldn't my check engine light just stay on if the computer was messed up
Old Mar 3, 2011 | 06:09 PM
el crapitan's Avatar
Default Re: NO POWER TO INJECTORS --NEED HELP--
if you have the original pcm, try disconnecting the conversion harness and reconnecting the original pcm just to see if they get power. it'll help narrow things down
Käras
16
May 10, 2011 07:23 AM
k20superchargedtuboitbs
Jan 31, 2011 07:44 AM
Acidcrakker
Nov 17, 2007 04:11 AM
firecivicman
Jun 30, 2007 08:41 PM
shyboi4u
Nov 17, 2005 01:05 PM
