Car shaking violently...
Old Sep 26, 2002 | 07:53 AM
onyx00's Avatar
Default Car shaking violently...
At idle when I am sitting in a parking lot or traffic the car shakes violently. It just started recently. I has a heavy shake to it, so it definately feels like it is comming from the motor, especially since the shake is in time with the motor.
Any ideas? Maybe motor mounts? Car has about 21K miles on it.
Thanks
Old Sep 26, 2002 | 07:57 AM
CPR's Avatar
CPR
Default Re: Car shaking violently... (onyx00)
Thanks
Have you done anything to the car recently?
Old Sep 26, 2002 | 08:00 AM
chad's Avatar
Moderator
check for lose bolts on the mounts.....all so cracked mounts....
Old Sep 26, 2002 | 08:14 AM
CW-ITR's Avatar
Default Re: Car shaking violently... (Chad)
A loose connection or crack ignition wire will does that too.
Old Sep 26, 2002 | 08:17 AM
TsunamiZC's Avatar
Default Re: Car shaking violently... (CW-ITR)
check for fault lines..it could be a earthquake...tee hee...j/k ....check the motor mounts....make sure there still good ....
Old Sep 26, 2002 | 04:46 PM
onyx00's Avatar
Default Re: Car shaking violently... (tsunami_zc)
Someone suggested misfiring in a cylinder; does that sound at all possible? Might explain it since once piston isn't firing so things are thrown out of balance.
Old Sep 26, 2002 | 04:47 PM
Type Goch's Avatar
New User
are you getting a CEL?
Old Sep 26, 2002 | 04:54 PM
B2FiNiTY's Avatar
Misfiring will give you a CEL. Check your motor mounts.
Old Sep 26, 2002 | 04:57 PM
onyx00's Avatar
Default Re: Car shaking violently... (ExOdy)
That was what I thought but my roommate said it wouldn't.
I will check the mounts. Gonna have a mechanic look at it tommarrow so we will see what they say.
Thanks guys
Old Sep 26, 2002 | 04:58 PM
BoroDB8's Avatar
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
yo0 prolly ate too many burgers
Old Sep 27, 2002 | 08:46 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Car shaking violently... (BoroDB8)
It could be a dead cylinder, if one of the plug wires is bad. With the engine idling, remove each plug wire from the spark plug, one a time, and put it back before going to the next one. The engine should run worse each time you take a wire out. If you remove one and the idle doesn't change, then that wire is bad, or it could be the distributor cap or rotor. One way or another, that cylinder is not getting spark.
Old Sep 27, 2002 | 10:52 AM
MikeD's Avatar
New User
Default Re: Car shaking violently... (PatrickGSR94)
wouldn't OBD2 log a misfire and trigger a CEL?
Old Sep 27, 2002 | 12:23 PM
onyx00's Avatar
Default Re: Car shaking violently... (MikeD)
I would think so, but not sure.
Old Sep 27, 2002 | 12:25 PM
B2FiNiTY's Avatar
So what did the shop say?
Old Sep 27, 2002 | 12:30 PM
TsunamiZC's Avatar
did they find that vibartor under you valve cover..that could be the problem .....
do you notice a loss of power ....while its shaking ?
if so then a dead cylinder could be the problem
Old Sep 27, 2002 | 12:33 PM
Dave-ROR's Avatar
misfire = CEL. there's a code for each cylinder.
Old Sep 27, 2002 | 12:35 PM
onyx00's Avatar
Default Re: Car shaking violently... (Dave-ROR)
Leaving in an hour to go to a buddies house and look at the car, will let you guys know. I have a feeling it is something with the plugs or distributor.
Old Sep 27, 2002 | 12:39 PM
Reid's Avatar
Global Moderator
It is most likely the motor mounts.
If it was a misfire, you probably would have reported the noticeable loss of power also.
guinnessstout
Honda Civic (2006 - 2015)
20
Nov 18, 2013 08:56 AM
shraz
Jan 13, 2009 10:33 AM
duffman1278
Jul 4, 2008 06:27 AM
TypeR0582
Jan 29, 2008 08:47 AM
See Are X
Feb 22, 2006 04:45 PM
