NAME this part plz
Old Mar 3, 2011 | 02:45 PM
frokido's Avatar
Default NAME this part plz
ok the vtec oil pressure sensor bolts into a housing on the back left side of the head RIGHT under the valve cover.. i need the name of that housing... just snapped it off the part the sensor bolts onto trying to tighten the sensor.. it go tto where it should have started tightening... ( not finger tight) and snapped off before it would tighten at all
the housing with the blue cap on ti... sensor bolts into, i brok ethe housing while tightening new sensor on it...
Old Mar 3, 2011 | 03:11 PM
Project H's Avatar
Default Re: NAME this part plz
you got a pic cause as far as i know the vtec oil pressure sensor is attached the the body of the vtec solenoid
Old Mar 3, 2011 | 03:13 PM
Project H's Avatar
And what motor are we talking?
Old Mar 3, 2011 | 03:20 PM
frokido's Avatar
d16z6 and is teh vtec solenoid the part that is bolted to the head with the plastic cylinder looking thing pointing up ( i think, mine has a blue metal cap over it). ill edit my post and add a pic
Old Mar 3, 2011 | 03:41 PM
frokido's Avatar
ok i figured out the part... is is the vtec solenoid. now anyone know where i can get a d16 vtec solenoid? been searching a while with no luck
Old Mar 3, 2011 | 04:39 PM
NOFX's Avatar
H-T White Ops
I couldn't list them off for you, but I know some VTEC solenoids work for various engines, models and years.
so you might want to look up the part number on a site such as hondapartsdeals.com and then do a Google search or search on here for the part number so you can figure out other cars that use the same one.
Old Mar 3, 2011 | 05:03 PM
Deetz's Avatar
Crazy Honda Guy
It's the vtec pressure switch......comes off the spool valve (vtec solenoid)
here's an example...
Old Mar 6, 2011 | 08:04 AM
Project H's Avatar
You can actually buy the vtec oil pressure sensor it think its like $50
RCautoworks
Aug 1, 2005 10:59 AM
boost fed ls
Mar 4, 2005 01:48 PM
ironchef25
Mar 1, 2004 02:50 PM
bey
Nov 27, 2002 09:06 PM
