One of my IACV hoses is cut
I got a 1997 civic HX nd my RPMS were bounicing up and down on idle, so i went nd looked at my IACV (idle air control valve) and one of the hoses are cut (the right one)...does anyone know where that hose goes connected to????
if i remember correctly, bottom of the throttle body or to the fast idle valve which is right around that area. just look around for a open nipple in that area.
The other two hoses are coolant lines and it doesn't matter which of the two you attach which hose: inside is only a chamber where the coolant circulates for those "special cold days".
https://honda-tech.com/forums/search...rchid=25845733
del sol b18c
Sep 10, 2007 11:43 PM
