Power Steering???? GSR vs ITR
Old Sep 26, 2002 | 06:50 AM
ITR#00-1077's Avatar
Default Power Steering???? GSR vs ITR
Just wondering why the steering in the ITR is stiffer than the other Integra models... that was the first thing I noticed when I first drove the ITR, before purchasing... and now when I drive my brother's GSR, the steering is too soft... now is there a way to adjust the stiffness to the GSR's steering??? and this is besides taking off the power steering belt... or is the ITR just stiffer due to the LSD??? but let me know guys.... I know he doesn't like it much and I sure don't like the steering to be that soft...
Old Sep 26, 2002 | 07:00 AM
NewR's Avatar
Default Re: Power Steering???? GSR vs ITR (ITR#00-1077)
I dont know about the GSR but I think ITR has "speed sensitive" steering. The turning varies with speed so I don't know if that contribute to the "stiffness" or not. hope it helps.
Old Sep 26, 2002 | 07:09 AM
Default Re: Power Steering???? GSR vs ITR (NewR)
Hmm.. that's new.. never heard that before, but.... I'll look into that.... but I still need different feedback..
Old Sep 26, 2002 | 07:56 AM
BSQ's Avatar
BSQ
All G3 Integras have the "speed sensitive" steering.
The Type-R does have stiffer steering rack bushings than the rest of the Integras. There are 4 bushings. I recently purchased the bushing from the Type-R, but I haven't installed them on my GS-R as of yet. So I cannot comment on whether or not they will change the responsiveness of the steering...hopefully they will.
Old Sep 26, 2002 | 09:34 AM
Philly_NBP_R's Avatar
Default Re: Power Steering???? GSR vs ITR (BSQ)
don't forget that stickier tires make a BIG difference in steering "feel"...
everybody knows that the michelins the GSR's come w/ are garbage, and ITR stock tires are
I don't know about any difference in the power steering system though - mine's "non-functional"
Old Sep 26, 2002 | 09:37 AM
Default Re: Power Steering???? GSR vs ITR (Philly_NBP_R)
Well, I understand the tire issue also... it's just like when there is too much air in the tires and the steering is soft as hell... but the GSR still does have softer steering... doesn't help much with no LSD (GSR) and one tire spins faster than the other...
Old Sep 26, 2002 | 09:49 AM
SoCal ITR's Avatar
I've driven both, and I definitely can tell a difference between GSR and ITR steering, I just never knew what that difference was.
Old Sep 26, 2002 | 09:51 AM
Reid's Avatar
Global Moderator
Default Re: Power Steering???? GSR vs ITR (SoCal ITR)
Try driving an ITR and GSR with the same suspension, wheels/tires and ITR steering rack bushings before making a comparison.
Old Sep 26, 2002 | 12:15 PM
jdmrealm's Avatar
New User
Default Re: Power Steering???? GSR vs ITR (Reid)
I THINK the ITRs PS pump is a bit diff from the gsr. I remember reading in a mag once how its diff to help get all the power they can out of the motor or something.
Old Sep 26, 2002 | 12:39 PM
Tweakmeister's Avatar
Default Re: Power Steering???? GSR vs ITR (4g63turbo)
the beefier rear sway bar plays a huge difference as well. face it...the ITR is totally decked out differently from the GS-R.
the difference is like tricycle to a bike.
but...the GS-R can be fixed up to outhandle the ITR....it's all about the complete package.
Old Sep 26, 2002 | 12:48 PM
erottik-R's Avatar
Apart from higher resistance tyres, boost is reduced to increase road feedback and response.
Old Sep 26, 2002 | 02:08 PM
92sleepR's Avatar
New User
I know for a FACT that the GSR and ITR racks (of the same model years) are IDENTICAL. The used part interchange #'s are the same and I have physically compared them as well. The rack bushings are harder on the ITR but a full ES bushing set is basically the same.
Mike
Old Sep 26, 2002 | 02:25 PM
Bbasso's Avatar
I heard that too
Old Sep 26, 2002 | 02:36 PM
ppihctyper's Avatar
Default Re: Power Steering???? GSR vs ITR (92sleepR)
your right!!!!! and so is the steering pump if I am not mistaken and the turns lock to lock are the same..... Don't you wish there was a way to make them with less turns lock to lock?
Old Sep 30, 2002 | 08:25 AM
Well, I guess I'll just have to pull the power steering belt out then... that seems easier than changing all those different parts... thanks for input and comments guys...
Old Sep 30, 2002 | 08:58 AM
uNF$@#!'s Avatar
Default Re: Power Steering???? GSR vs ITR (ppihctyper)
i think i count 3.5 turns to lock.
litterbox
Jan 17, 2005 03:58 PM
Doctor CorteZ
Feb 22, 2003 06:54 PM
92TypeR
Dec 8, 2002 01:24 PM
