1994 accord idles rough
Old Mar 2, 2011 | 02:28 PM
wanting an EF's Avatar
Default 1994 accord idles rough
i am thinking of buying this 1994 honda accord tomarrow with 195,000 miles and the only thing wrong with it it is idles a bit rough. Any suggestions on what to look for to fix it?
Old Mar 2, 2011 | 02:42 PM
accord_raffi's Avatar
Default Re: 1994 accord idles rough
It could be several things.
Plugs, wires, distributor. (easy)
Oil getting into the spark plugs (grommets inside the valve cover and more gaskets under the rockers. 8 total). (valve cover ones are easy, the others take more time)
IACV might need to be cleaned (easy)
You could check the FITV but that's usually a problem only when it idles high and holds there.
I doubt it's a fuel problem because if the pump was faulty, the car wouldn't turn on or it would stall out eventually.
Old Mar 2, 2011 | 02:44 PM
so it's an easy fix most likely? he says it might have a stuck valve.
Old Mar 2, 2011 | 03:09 PM
CDdubz5's Avatar
compression test it, that will tell you if it is a stuck valve, if it is i would walk away unless you want to do a tear down of the head
Old Mar 2, 2011 | 03:50 PM
i think im gunna go ahead and nab this car up and do the small simple things first. and then if its still rough ill take it to the shop and have them fix it. If it was a stuck valve wouldn't the CEL come on?
Old Mar 2, 2011 | 07:52 PM
quickster's Avatar
rough idle might be air in the coolant system or a bad motor mount as well.
keoman
11
Feb 8, 2014 01:56 PM
Packie12321
Oct 23, 2013 11:30 AM
lfdelar2
May 21, 2013 10:01 AM
Hawkmoon
Jan 2, 2003 03:38 PM
