clutch inconsistency
Old Mar 2, 2011 | 12:55 PM
vt_hokie2008's Avatar
Default clutch inconsistency
00 Si with JDM Type R swap (engine and trans), stock clutch, fidanza flywheel
Once everything is heated up, my clutch will start to engage as soon as I start letting the pedal out for about an inch or so, then it disengages and re-engages where it should. It doesn't do this every time and doesn't do it at all when everything is cold. I've completely flushed the clutch fluid with new and it didn't change anything.
Old Mar 2, 2011 | 01:36 PM
Former User's Avatar
Default Re: clutch inconsistency
Damaged clutch fork? Faulty MC or slave cylinder?
Old Mar 2, 2011 | 03:02 PM
ferioLSv's Avatar
also check for fluid leaks.... make sure yuor clutch master cyl isnt leaking inside on the carpet
Old Mar 3, 2011 | 07:33 AM
will do, thanks
Old Mar 15, 2011 | 07:15 AM
I have no leaks. Does this narrow it down any?
Old Mar 15, 2011 | 07:36 AM
grumblemarc's Avatar
The Grumpiest
B_Swapped93
Sep 19, 2013 04:42 PM
tercelrcr
Feb 2, 2013 06:25 AM
Lb1atx
Sep 7, 2007 05:16 AM
cactusman
May 6, 2006 11:41 AM
Fullthrottlegsr
Jun 22, 2005 01:21 PM
