Ideal turbo manifold runner length??
Hey guys,
I'm going to be building myself a front facing turbo manifold soon and I'm trying to do some research before I start trying fab this thing up. I've tried searching for ideal runner lengths, how to calculated the total length of each runner after having several bends and I have not found any clear answers on this stuff. I would really appreciate and input or advice on making a decent manifold.. Thanks in advance!!
That's what I was thinking, I already have the location that I want the turbo to sit at so I guess I start by making the first runner and then I'll try to make the other 3 as close as possible to the first one.
The best runner length and diameter is going to depend on how much air the engine uses, and where you want the power band. This also changes when the motor is boosted. It isn't exactly cut and dry, the "best" changes from motor to motor.
I'm looking to put down 800hp+ with my setup when it's done but I want to leave room for more power. I'll proably just take the best guess that I can and build a manifold, it will be a good learning experience since it's going to be my first manifold..
equal length does not = equal flow. unless all the runners are identical. equal length is just a catch phrase used to sell manifolds by people who think they know what they're talking about.
as long as you keep the runners uniform and equal length as possible you will be fine. if you wanna get down to the fine print, then yes equal length tubes wont have equal flow if one has more bends in it than the other....but who in their right mind would build a runner with about 180 deg of total bend and another runner with 400 deg of total bend?
for f/i, keep the runners as equal length as possible and try to use the same degree of bends for each runner as possible.
for n/a, we do the same as above but length plays a very important role...especially when you start making step headers.
just have a nice merge collector and good wastegate placement and you'll be fine. keep the wastegate branch as short as possible to avoid cracking issues.
also, thicken up your welds for better penetration...and shorten up your weld start and stops for better gas coverage.
here's a shot off one of our production collectors for reference.
i would try to clock your collector a little more upward to make for easier transitions when you go to fabricate the runners. even if it means decking it at an angle prior to welding it to the flange.
