working on my $200 honda civic
just bought this 89 civic dx for 200 bucks its in pretty bad shape but i am pulling all the parts I need off of one of my old projects
I will be replacing
Doors, panels
fenders
seats ( integra tweeds)
dash
carpet
heater core
headliner
exhaust
wheels (fat fives)
lower control arm (front pass)
front pass ball joints
and im sure there are some things that im forgetting
and finally paint
I will be replacing
Doors, panels
fenders
dash
carpet
heater core
headliner
exhaust
wheels (fat fives)
and finally paint
so last night I started removing the LCA because on of the bolts for the front stabilizer broke off inside. ball joints and strut came off no problem but when I got to the bolt that connects to the subfame the bolt seams to have welded itself to the bushing inside
I cut through the bolt with an angle grinder and removed the LCA.
p.s. u can upload multiple pics in one post garth
ok so I am having trouble getting the stabilizer bar off of the lower control arm
I have already cut the bolt attaching the LCA to the subframe
any help? I have allready soaked the SOB real good over night too but still wont budge
yeah im gonna try the heat later...
also any tiops to get the bolt out of the subframe?
after cutting out the LCA i realized **** that bolt is still stuck in subframe
w/out looking at it, i would say probly drill out and re-tap. its gonna suck, but car that old this stuff happens
Maybe try a bolt extractor.
I would soak, heat/cool, everything, etc. before considering to cut a bolt. Getting whatever is left out is a pain.
Also, you can take your bumper off and remove the nut holding the bar on.
Then you can pull the LCA and bar off together and work on them out in the open.
Maybe try Marvel Mystery? I've used both PB Blaster and Marvel and there have been a couple of instances where Marvel worked when PB didn't. Also, you might try relieving the tension off the crossmember end of the stabilizer bar. It might let you wiggle it a bit since it looks like you already got the other bolt out.
no the other bolt broke off inside the Lower control arm, that and bad bushings is why I am replacing it, plus i have a good one
but here are the pics of the bolt stuck in the subframe, its a real bitch trying to get in there with anything, but maybe after i pull the upper ball joint and strut i will have more room to work
but back to the subframe.....
here are the pics
[IMG]
[/IMG]
should I try to cut off the head of the bolt then pop it out with a punch? any better ideas cuz its hard to get my angle grinder in there
here are the pics
[IMG]
[/IMG]
Also I have removed the two brackets holding the radiator in place and just slid it over since part of it was blocking access to the nut on the stabilizer bar under the bumper (which did not need to be removed)
I am having a difficult time getting any leverage on the stabilizer bar since the LCA is not attached to anything and the whole bar just rotates slightly im going to soak in it PB and try again
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
and a pic of my last civic which made it to 427,000 miles before i sold her something I will always regret
[IMG]
[/IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]and a pic of my last civic which made it to 427,000 miles before i sold her something I will always regret
[IMG]
[/IMG]
so i just keep hitting the bolts with pb blaster and hoping but at dont want to spend all the time I have to work on my car messing with these two bolts
so today I removed the passenger side fender, airbox under the bumper, and passenger side door
here is a pic of the days progress
[IMG]
[/IMG]
only took like 20 mins
[IMG]
[/IMG]only took like 20 mins
[/IMG]
