Help me whit winter storage
Old Sep 26, 2002 | 06:16 AM
Toda's Avatar
Default Help me whit winter storage
I am going to put my R in winter storage for 6 month, but I have a few questions.
This is what I thinking about to do.
Place the whole car on jack stands, not on the chassis but on the suspension linkage.
Change the oil for a god oil, but not replace the filter, in the spring I will change the oil again whit the best oil and a new filter.
Put some oil in the cylinders and crank it a few times.
Of course I will wash and clean it before I put it to storages.
Does this sounds right or do I have to do something more?
Should I fill it up whit gas or run it empty?
What fuse do I have do disconnect so it don’t inject gas into the cylinders?
Old Sep 26, 2002 | 06:26 AM
JPP's Avatar
JPP
Default Re: Help me whit winter storage (Toda)
Sounds good
I personnaly put the stands on the chassis but put some wood blocks under the suspension to keep it halfway compressed
Keep the tank full of gas to prevent condensation in the lines. Also put some gas stabiliser in the tank. Remove the battery and bring it inside (good time to give it a good charge). Make sure you have the radio access code for when you will start her back up in the spring.
I will also try to find a way to protect the brake rotors this winter. Not sure what to do yet.
Old Sep 26, 2002 | 06:30 AM
1.8Tities's Avatar
Default Re: Help me whit winter storage (JPP)
I also heard that make sure you crack the window a lil bit probably half an inch to prevent moisture inside and to let the interior breathe..
Old Sep 26, 2002 | 06:34 AM
Mugen Mike's Avatar
I just over-inflate the tires to prevent flat-spotting. I've been told that putting the car on jackstands for that long is bad for the chassis.
What needs to be protected with the rotors?
Old Sep 26, 2002 | 06:35 AM
Keane Rated R's Avatar
sounds good to me, I'm also interested in how much fuel to keep on the car..
I plan to take it out 3 times a week and let it run for while...
Old Sep 26, 2002 | 06:50 AM
JPP's Avatar
JPP
Default Re: Help me whit winter storage (mugenmike)
I would like to find a way to prevent them from rusting as much as they do.
Old Sep 26, 2002 | 07:05 AM
Mugen Mike's Avatar
Default Re: Help me whit winter storage (Keane Rated R)
Tank should be full. Also add Stabil to the tank
BTW: 3 times a week is overkill. Once or twice a month is fine. I also like to scatter mothballs around underneath the car. It keeps the rodents away.
[Modified by mugenmike, 10:12 AM 9/26/2002]
Old Sep 26, 2002 | 07:08 AM
Mugen Mike's Avatar
My rotors show surface rust after sitting overnight in the rain. Nothing a quick drive around the block won't cure.
Old Sep 26, 2002 | 07:17 AM
JPP's Avatar
JPP
Yes mine does that too. However, after 5 month of inactivity during a canadian winters, my rotors end with a little more then slight surface rust.
Old Sep 26, 2002 | 10:34 AM
Toda's Avatar
Somebody?
Old Sep 26, 2002 | 10:38 AM
JPP's Avatar
JPP
You could remove the fuel pump fuse or the PGFI fuse.
But if you remove the battery, it pretty much prevent everything from doing anything.
Old Sep 26, 2002 | 11:00 AM
Toda's Avatar
Somebody?
I want to crank it a little bit with some oil in the cylinders without it to inject fuel into the cylinders.
Old Sep 26, 2002 | 11:17 AM
JPP's Avatar
JPP
Somebody?
In that case, you can simply disconnect the injector clips (electrical connector coming to each injectors) for the time you are cranking the engine and reconnect them afterward.
Old Sep 26, 2002 | 11:30 AM
nsxtcjr's Avatar
New User
The advice on removing the battery was good - or, even better, you can leave it in the car, and install an onboard charger like this one, so it's always there on your car, any time you need to let it sit. But don't pay $36.99; you can get it for $25 at a bunch of places mentioned here.
With all you're doing to prepare the car for storage, you should be fine just letting it sit, without taking it out at all.
And, if you do that, don't forget to call your insurance company and suspend your liability and collision coverage, leaving only comprehensive. You'll save a lot of money that way.
dc2LS
Aug 28, 2012 06:34 PM
00civiccali
Jul 21, 2008 09:15 PM
don24
Mar 7, 2006 08:34 PM
Ax3l
Jul 19, 2005 04:21 AM
ucb
Apr 24, 2003 01:31 AM
