$$$ for honda key replacement EG
Old Mar 1, 2011 | 07:22 PM
polyhonda's Avatar
Default $$$ for honda key replacement EG
Does anyone know the price for a replacement key from honda for like a 1993 honda civic?
thanks
Old Mar 1, 2011 | 07:28 PM
egsleepercivic's Avatar
Default Re: $$$ for honda key replacement EG
think it was about $9 last time I needed one
Old Mar 1, 2011 | 07:46 PM
Project Dad's Avatar
shoot i took my registration in to honda dealer and the guy made me one. was like $2.06. and this guy did it by hand not with a machine
Old Mar 1, 2011 | 07:55 PM
polyhonda's Avatar
yeah I totally lost my keys so I just need to bring them my registration and license right.
Old Mar 1, 2011 | 07:59 PM
yep, if the registration is locked in the car the title should work also
Old Mar 1, 2011 | 08:21 PM
lshatch98's Avatar
insurance card will work too if it has the vin(mine does)
Old Mar 1, 2011 | 09:06 PM
NOFX's Avatar
H-T White Ops
Bring in:
Photo ID
Proof of ownership
$10
Last time I got a key cut it cost about $7 iirc.
Old Mar 1, 2011 | 10:45 PM
tklee's Avatar
LOL
Old Mar 2, 2011 | 10:59 AM
HatchbackSqueegee's Avatar
Blank keys are $1.53 at dealer + key cut if needed.
Old Mar 2, 2011 | 04:25 PM
wow they must have cut me a deal. was $2 and change total. didn't even look at my license, or ask for it.
Old Mar 2, 2011 | 04:48 PM
Libertariat's Avatar
Ek Forever y0!
I bought a blank off of ebay for about $5 years ago and had a local shop match it to the ghetto one I got with the car.
Works perfect.
Old Mar 9, 2011 | 11:39 AM
Update 1993 Civic key was $1.53 at dealer Cut was free and done by VIN! Check out the difference of a new key and one with 230k Miles on it!
Edited picture to prevent theft
Last edited by HatchbackSqueegee; Mar 9, 2011 at 01:07 PM. Reason: Edited picture to prevent theft
Old Mar 9, 2011 | 11:58 AM
NOFX's Avatar
H-T White Ops
The only problem now is that the lock cylinders might also be worn, which means other worn keys might be able to open those locks.
Old Mar 9, 2011 | 12:24 PM
my thoughts exactly. I have done this with other makes. my 05 dodge ram key will unlock my 91 dakota door but not the ignition.
if it wasn't for the VIN matching to the locks I would say replace them all. $$$
Old Mar 9, 2011 | 12:29 PM
NOFX's Avatar
H-T White Ops
I'm sure you could get the same keyed locks redone. That is, they would use the same original key code and all.
Might be a better idea to go to a locksmith, but IIRC Honda also sells the kit to re-pin the lock. Not so sure if doing that for the first time sounds fun to me though...
Already pulled the cylinder out of the lock assembly. Don't like that. Too easy for it to fall apart and not work right afterward.
Maybe with some guidance though...
Old Mar 9, 2011 | 12:31 PM
waspcrx19's Avatar
dude its so cheap. I bought my shell with no key and just went to the dealer and showed them the vin and done
Old Mar 9, 2011 | 12:41 PM
NotAJDMFanBoy's Avatar
I've heard similar, but I didn't think it was that far of a range in years.
And I had issues with very worn keys not opening my doors very easy. Getting it cut by VIN and then keeping an extra pristine condition one tucked away in a lock box or something may be a good idea. Just in case.
Old Mar 9, 2011 | 01:14 PM
The only "problem" I have had is my key WORKS like new!! Glad I had it cut by VIN# for $1.53
I did buy some graphite and that was $2.50.
Old Mar 9, 2011 | 01:22 PM
NOFX's Avatar
H-T White Ops
I don't think you understand what I just said.
I'm sure the new key will work just fine. The problem could be that since the pins in the cylinder on the car are worn, other keys could open it. It is likley that since your other key was that worn, your pins in the cylinder lock are also worn.
Old Mar 9, 2011 | 02:42 PM
And I don't think you understand what I said. My worn key wasn't working. I got a new one, and the new one worked.
BTW: I have a 94 civic si, and I've tried key switching on both. Doesn't work.
Old Mar 9, 2011 | 05:35 PM
NOFX's Avatar
H-T White Ops
Then if your key was so worn that it wasn't working, it's great you have it working again. I didn't see you mention that before though, so I wouldn't have known.
Just letting people know that the pins in the cylinders wear as well, so that might be something they want to keep in mind as well. Granted Civics are usually easy enough to break into that another key isn't needed.
Old Mar 13, 2018 | 06:44 AM
amlee17's Avatar
I just called the dealership for my 1993 Del Sol and they want $10 CAD per key (spare or valet) and $25 CAD to cut it.
So, I went eBay and bought a set (spare and valet) for $15 USD and a spare for $2 USD.
As these are not transponder keys, is it possible to get them cut at a local locksmith?
Old Mar 16, 2018 | 02:37 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
^ Funny... On three occasions already, I have shown up at the Honda dealer with my own 92-95 Civic key (purchased for <$2 online) and the dealer has waived the key-cutting cost. This is in Canada.
SouthSider13
21
Jul 15, 2010 08:18 AM
lilshady6796
Nov 14, 2008 06:05 PM
alacard
12
Nov 22, 2006 12:54 PM
wm5holla
Feb 8, 2003 01:36 PM
L4NDO
Apr 22, 2002 01:47 PM
