LS dash in EG...Does it just plug up if using LS dash wiring harness?
Old Sep 26, 2002 | 05:32 AM
HybridCoupe's Avatar
Default LS dash in EG...Does it just plug up if using LS dash wiring harness?
Will eveything plug up and be functional with the integra dash harness plugging into civic fues box?
Old Sep 26, 2002 | 05:43 AM
Plan B's Avatar
Default Re: LS dash in EG...Does it just plug up if using LS dash wiring harness? (HybridCoupe)
https://honda-tech.com/zerothread?id=285567
Old Sep 26, 2002 | 09:04 AM
Default Re: LS dash in EG...Does it just plug up if using LS dash wiring harness? (Plan B)
still doesnt explain the wiring......
Old Sep 26, 2002 | 12:32 PM
Plan B's Avatar
there is not plug and play option here. Get out the soldering iron and the multimeter.
But then again, i suppose if you wanted to take the entire car side wiring harness from and integra it might work, but install would be the biggest ***** ever.
Old Sep 26, 2002 | 12:49 PM
yaya's Avatar
you need the plugs that fit into the integ dash....cut all the wires out of the civic plugs
you are only changing the plasitic plugs and the dash right?
there are like 8796987 post on this SEEAAAARRRRCCCHHHH
Old Sep 26, 2002 | 12:52 PM
Default Re: LS dash in EG...Does it just plug up if using LS dash wiring harness? (yaya)
yea thats what im doin and i have both complet wiring harnesses
Old Sep 26, 2002 | 01:31 PM
yaya's Avatar
ok so you use the plastic plugs from the integ dash and pull out the wires from your civic PLUGS....its a bitch and i dont have a diagram for it.....you can just label each one with some masking tape and do it like that
are you cutting your instrument panel frame thing so it will fit?
Lexxi_TegK24
Dec 4, 2012 02:32 PM
gummiegorilla
Jul 30, 2009 07:32 PM
shivic
Apr 26, 2004 03:08 PM
92B20GSR
Oct 16, 2003 06:10 PM
HybridCoupe
Sep 25, 2002 03:58 PM
