M&W PRO-10 Ignition (TONY1 Chime in)
For a M&W PRO-10 ignition, where do you connect the trigger wire to? The M&W bypasses the stock ignitor. The stock ignitor has a white w/Blue stripe wire and a solid blue wire as its input Which one of the two wires do you use for the trigger input on the M&W?
(Output of the ignitor is the black w/ yellow stripe and white w/ blue stripe; both of which wont be used).
Thanks
Thanks
Per the instructions at http://t1racedevelopment.com/images/...structions.doc
It goes directly to the ecu at pin A21 (ICM signal).
juicy.koreans.suck
Mar 20, 2002 05:03 PM
