JDM and USDM crossmember
Old Mar 1, 2011 | 04:05 PM
civic'x's Avatar
Default JDM and USDM crossmember
hi guys....i need your help what is the difference between jdm and usdm crossmember.... somebody with pics to see example....thanks
Old Mar 1, 2011 | 04:07 PM
JDM_rolex's Avatar
Default Re: JDM and USDM crossmember
Maybe the JDM ones are made to clear the B16 headers. Thats about all that i can think about.
Old Mar 1, 2011 | 06:45 PM
blaak-crx's Avatar
Bolting pattern points are different on the frame.....So can't use it on the USDM...
Old Mar 1, 2011 | 06:46 PM
jdmboyef9's Avatar
Are we talking front or rear? If memory serves me right the JDM one was different. I would recomend either using your stock one or an after market one. Unless you have the JDM tie rods, you might be in trouble.
Old Mar 3, 2011 | 07:51 AM
civic'x's Avatar
ok thanks but what do i need to use the jdm on the usdm..?or is impossible
Old Mar 3, 2011 | 06:18 PM
jdmboyef9's Avatar
I would lean towards not possible. I'm sure it can be done with modification but the JDM one is heavier and doesn't benifit you.
B_Swapped93
May 6, 2014 06:28 AM
DESTROYDCB7
Jun 14, 2011 11:02 AM
hondaistheboss
Honda Civic (2006 - 2015)
14
Feb 19, 2008 07:53 AM
iwhichisme
27
Aug 1, 2002 12:51 PM
5-SpeedFreak
Nov 9, 2001 05:21 AM
