lsvtec coolant hoses.... help needed!
Old Mar 1, 2011 | 11:51 AM
LSTurbo23's Avatar
Default lsvtec coolant hoses.... help needed!
I have a b16 head on a b18a1 block. i looked at coolant diagrams for both engines but im still lost. Do i have to use the b16 thermostat housing? Im using the LS one and cant figure out what hose goes to the two ports on the housing closest to the water pipe. I have the sensor hooked as well as one hose going from the therm. To the intake manifold. Also the fan switch on the head under the vtec solonoid....theres no plug on my harness for it. Do i have to extend wires for it? Any help with the coolant hoses will be appreciated cause im stumped and need to start my car.
Old Mar 1, 2011 | 06:53 PM
LSTurbo23's Avatar
Default Re: lsvtec coolant hoses.... help needed!
Anybody?
Old Mar 2, 2011 | 06:20 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The All Motor forum may be of more help, or peruse this thread and post if needed.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
To answer your question, it appears in this diagram that one hose #3 goes from the housing up to the intake manifold flange, while the other hose #6 goes up to the throttle body.
Old Mar 3, 2011 | 04:46 AM
LSTurbo23's Avatar
Thanks a lot man!!
dirtygerman
Apr 28, 2013 04:43 AM
Zalitore
Jul 2, 2007 10:42 AM
boostedcivicsir
Feb 28, 2007 05:04 PM
crxb20ed
Jan 5, 2005 12:22 PM
nacho_man
Nov 13, 2004 04:52 PM
