obd2 b20b into 00 integra injector prob
Old Mar 1, 2011 | 11:51 AM
msncml386's Avatar
Default obd2 b20b into 00 integra injector prob
Ive searched this and found all kinds of crap any help would be awesome. I swaped my 2000 integra with a jdm b20b i have all the obd2 stuff the injectors, distributer, and computer and i cant seem to get the injectors to fire i have fuel pressure, spark but the injectors dont fire. What could be the problem what in obd2 cars causes the injectors not to fire.
Old Mar 1, 2011 | 11:53 AM
Marcin_519's Avatar
Default Re: obd2 b20b into 00 integra injector prob
change the injectors maybe my friend wen he bought his jdm b20 2 injectors were seized or something try to change them or clean them use ur old once?
Old Mar 1, 2011 | 05:54 PM
1998GsRIntegra's Avatar
Have you verified that you are getting proper voltage to each injector?
Old Mar 1, 2011 | 07:21 PM
msncml386's Avatar
yeah im not getting any power to the injectors.
Old Mar 1, 2011 | 07:37 PM
crexer's Avatar
just out of curiosity did you use your integra injectors or was it even possible to use the b20b injectors?
Old Mar 1, 2011 | 07:49 PM
msncml386's Avatar
I used all of the b20b stuff that came on the motor.
Old Mar 1, 2011 | 08:56 PM
mark@silbernage's Avatar
Please clarify regarding power to the injectors... Is there a steady 12 volts on the battery side of the injectors (i.e. yellow/blk)? It is fed from fuse 31 (15A) in the under-hood box, through the yellow/white to the main relay, and then directly to the inectors.
If there is 12V there, then (harder) can you tell if the ECU is pulling the low side (blue) of the injectors down when it's time to fire? You could check continuity between the injector connectors and the ECU pins A1 (inj4), A2 (inj3), A3 (inj2) and A4 (inj1); in case there was a wiring mix-up or connector problem.
Mark
EJ8 GSR-T
Apr 26, 2006 06:33 PM
civictyper99
Dec 5, 2003 01:25 PM
smashed4thgen
Oct 18, 2003 04:43 PM
DelsolVtec18
Oct 5, 2001 03:56 PM
