notice the tach...
****, I've got OCD but I'll give you props for even noticing it. Are you actually hearing any difference in the motor at those speeds/rpms? Is your rev limiter doing that all the time or just when you first start it up?
yeah im noticing a difference in the sound. my first car ever was a 93 civic and i didnt have a tach so most of the time i drive by sound. and the limiter does it at all times
If you hear a sound difference then it is possible your engine is actually running at different RPM's.
Have you done preventative stuff lately?
EGR Ports cleaned
FITV/IACV/TB cleaning
etc
EGR Ports cleaned
etc
i changed the egr valve...i cleaned the TB when I changed the motor because i re-used the TB and intake manifold...i dunno what that other stuff is that u listed...i am easily taught on anything mechanical tho so if u dont mind enlightening me on the subject i would greatly appreciate it
Well if you figure it out let me know---have a 95 EX and have the same.
Mornings-can run 65 mph at 2,000 rpm's (summer or winter), all the way to work. In the evenings-most of the trip have @ the same rpm's but at the end of the trip I'm running 2,500 at 65 mph. Yes the same-it is the engine rpm's, not the tach.
I'm almost sure it has to due with the fluid-before you go there, I drain and fill the trans with Z1 (soon to be DW1 if you don't know) every 10K. Last reach is that the solenoids are not sealing off and a bit of pressure is bleeding by not allowing full lock-up.
And I have the same OCD about all of this and many other things when it comes to the car....and btw, mine has about 165K more on it than yours.
EDIT: And my stated rpm's are once the converter "locks up". Before that, well we all know they are higher.
Last edited by poorman212; Mar 4, 2011 at 05:15 PM. Reason: I can't spell worth.....
Ok I wanted to follow up on this because I got another ECU and I'm still having the same issues...I read somewhere while digging for similar threads that a guy with identical issues changed his and it fixed it...any clues?
stealth89hatch
13
Jun 17, 2005 03:25 PM
Tr0LL
Jun 29, 2003 09:24 AM
