Quick part question for 02 RSX-S
Old Mar 1, 2011 | 08:52 AM
SiR-G DC's Avatar
Default Quick part question for 02 RSX-S
So, I've had a little idle problem on my newly acquired RSX-S. We tried switching out throttle bodies but nothing. Replaced intake manifold gasket, New from Honda. Throttle body gasket, New from Honda. Oil pump, Chain, and a bunch more things from Honda (It has 125K on it with a rebuilt fresh head I put on) Every time i put my finger over the hole in the throttle body (Where the IACV sucks air) it drops to idle and runs fine? We took off the IACV and cleaned it up because it was "Stuck". Now onto the part question. Would the piece pictured have anything to do with it? I'm not sure but the top black part (Sensor/plug, It sucks in air from the Intake Manifold) that goes into the head. Well where the hose goes it spins, Not sure if it's suppose to an not sure if that would affect the idle? It's over $100 at the dealer and I don't want to get it and it not be the problem, But the one i have does spin, So if that does affect anything, Well to the dealer i go.
Here's a picture of the piece/hose I'm speaking about, Sorry there's not a better picture as my car is at our shop right now.
TIA!
Old Mar 2, 2011 | 08:00 AM
SiR-G DC's Avatar
Default Re: Quick part question for 02 RSX-S
Nothin?
Old Mar 2, 2011 | 08:59 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
that part you are referring to is a fuel injector warm up bypass valve.
it does nothing of importance to idling in my opinion. Hence I pull it off all my customers cars for wire tucks.
Old Mar 2, 2011 | 10:21 PM
SiR-G DC's Avatar
Is there a block off plate or something for it? It pulls vacuum so i can't just pull it off?
Old Mar 3, 2011 | 08:42 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
you put a NPT plug where the valve was (found at hardware store) and put a rubber cap on the intake tube (found at autozone)
Old Mar 4, 2011 | 07:34 AM
SiR-G DC's Avatar
Thank you sir
feriotypeR
Oct 10, 2009 03:58 AM
DOHC Kid
May 4, 2008 02:43 PM
ridin98civic
10
Feb 2, 2007 11:11 AM
90AcuraIntegra04
Feb 4, 2006 02:18 PM
bryan99si
11
Sep 8, 2005 09:35 PM
