Bolts on back of B18A block
Old Mar 1, 2011 | 06:36 AM
91DA-C's Avatar
Default Bolts on back of B18A block
Does anyone know what size bolts are circled in red in my picture? I took them off when I took my motor apart before I brought it to the machine shop and I can't find those bolts and need to get replacements.
I can't find the name for them, size of the bolt or part numbers, so any such information would be appreciated. I checked my Helms manual for the car and the only bolt I see is the 28mm drain plug on the front of the block behind the header.
Thanks.
Old Mar 1, 2011 | 07:00 AM
mouab18c1's Avatar
Default Re: Bolts on back of B18A block
Honda part # 11107-PK2-003
Old Mar 1, 2011 | 07:15 AM
91DA-C's Avatar
Thanks. Is that part # the same plug for both holes? I had a breather box which was replaced with an Endyne catch can if that helps any.
Old Mar 1, 2011 | 08:43 AM
mouab18c1's Avatar
Yeap same parts for both holes. You will also need the crush washer as well. The first picture is a setup of the Endyn catch can setup
Old Mar 1, 2011 | 09:12 AM
91DA-C's Avatar
Great, thanks man!
chriscool888
Jan 9, 2011 09:54 PM
jlfrnce
Sep 23, 2009 10:54 AM
all_motor_sfwd
Dec 25, 2007 08:50 PM
slowteg90
Sep 6, 2007 04:20 PM
zerovandez
Jun 2, 2006 06:07 PM
