Will bmw wheels fit my eg civic????
Old Feb 28, 2011 | 03:25 PM
michjdm's Avatar
Default Will bmw wheels fit my eg civic????
hey does anybody know if some 14' BMW E30 basketweaves would fit my 95 civic? please help! thanks!
Old Feb 28, 2011 | 03:29 PM
vartok's Avatar
Default Re: Will bmw wheels fit my eg civic????
I believe so, ive seen a few on civics... if they are 4x100 bolt pattern there shouldnt be an issue
Old Feb 28, 2011 | 03:43 PM
michjdm's Avatar
thanks^!
Old Feb 28, 2011 | 07:41 PM
michjdm's Avatar
anyone else?
Old Feb 28, 2011 | 07:51 PM
votoms888's Avatar
e30 BMW 3-series are all 4x100. I think only the M3 might be different. I think the hub bore is different so you may need some hubcentric rings.
Old Feb 28, 2011 | 07:57 PM
michjdm's Avatar
does that mean i cant just stick em on? lol
Old Feb 28, 2011 | 08:26 PM
92lxsleeper's Avatar
o you can just stick them on. they might vibrate and break your studs off and the wheel go flying off the car on the highway is all.
Old Feb 28, 2011 | 08:35 PM
michjdm's Avatar
haha ill take that as a no
Old Feb 28, 2011 | 08:48 PM
trevek10's Avatar
this is a silly question... you can put any wheel on as long as there are the same pattern .. which is 4X100 there is also 4X114 so dont be confused if wheels with 4 lug pattern dont fit ... i believe bmw uses 4 x114 (correct if im wrong) so no they will not fit and you can not just put them on it will be imposible if they are not the right size its not a matter of breaking anything...
Old Feb 28, 2011 | 09:38 PM
TypeRMOBBiN209's Avatar
theres 4x100 so they will fit!! i had a friend with them on his integra without hubcentric rings and never had a problem..i think hubcentric rings are more necessary for cars that use bolts rather then studs, but just to be safe i'd run the rings
Old Feb 28, 2011 | 10:01 PM
votoms888's Avatar
All BMW e30 3-series uses 4x100mm bolt pattern. The only difference is with the M3 that has a 5x120mm bolt pattern.
Old Feb 28, 2011 | 10:02 PM
Damir314's Avatar
if they are 4x100 they should fit no problem. one of my buddies has been rockin some bmw meshes on his 96 civic for a couple years now
Old Feb 28, 2011 | 10:04 PM
michjdm's Avatar
well the ones im getting are 4X100...so now with info provided, i have no doubt in buying them..thanks for the info!
Old Feb 28, 2011 | 10:10 PM
votoms888's Avatar
That is because he relied on the lugnuts to keep the wheels centered. Chance of an off centered wheel is eliminated because it relies on a proper sized ring to center the wheel. Furthermore if hub centric rings are not used it puts more load on the wheel studs. If you hit a pot hole or bump it could damage the wheel studs. The hub centric rings pass on "some" of that load to the hub. Even though some are made of plastic they are still very effective.
Old Feb 28, 2011 | 10:12 PM
votoms888's Avatar
Not necessarily. If the hub bore in the wheel is smaller than your hub than it might be a bit difficult.
Old Feb 28, 2011 | 10:28 PM
crazyboy's Avatar
i have an e30 and a crx. my crx has no spare, when the tire went flat i threw my bmw spare on it and it ran fine, i gotta 89 325i
like my friend spikes car (tell me to take it down if u have a prob with me postin)
Old Mar 1, 2011 | 04:45 AM
BlueIntegraBoy's Avatar
https://honda-tech.com/forums/honda-acura-28/post-pics-your-bmw-bottlecaps-1731304/
k24coupe
Mar 7, 2012 06:50 AM
ten2doyle102
Dec 11, 2009 05:38 AM
admit1
Honda Fit
Sep 28, 2006 06:34 AM
digglewitz
Jan 28, 2003 12:55 PM
