machining caliber bracket
Old Feb 28, 2011 | 02:32 PM
blown_ss's Avatar
Default machining caliber bracket
ok so here is the deal. i have a 95 integra gs. i just bought a set of wheels and when i went to mount them the front caliber bracket is in the way. most people run wheels spacers but the wheels are already wide and a low offset so i didnt want to use them. what im wondering if i could machine/shave some of the caliber bracket off so that the wheel will fit. the bracket mounts on the spindle and wraps around the rotor. i have searched for hours looking for some info on this but all i can find is the write up on how to do a itr brake swap. someone please help me out on this.
i dont want to hear anything about getting new wheels or anything about running low offset wheels. thank you.
Old Feb 28, 2011 | 03:47 PM
fcm's Avatar
fcm
Old Fart
Default Re: machining caliber bracket
How much do you need to remove? 94
Old Feb 28, 2011 | 04:03 PM
blown_ss's Avatar
not really sure. i didnt play with it too much before i started searching. the whole shape will still be there from what i remember. i mainly need to trim it down. i dont know how important the from part of the bracket is so that is why im asking.
Old Feb 28, 2011 | 07:09 PM
fcm's Avatar
fcm
Old Fart
"the from part of the bracket"
As long as you do not interfere with the "structure", [removing material in places that would weaken the caliper or bracket, interfere with the pad mounting, or compromise the hydraulics] you should be OK, keep in mind, the caliper is a heat sink of sorts, so if you do remove material, remove as little as possible. 94
Old Feb 28, 2011 | 08:28 PM
blown_ss's Avatar
its the part that wraps around the bottom of the caliber in the front. the bracket is too close to the middle of the rotor and i just need to remove a little to get the wheels to fit. i think that i would be ok i just wanted to see what someone else thought about it before i did it. i know im not the first person that has needed to do this or have done it.
Old Mar 1, 2011 | 09:54 AM
MR.johnson's Avatar
yes you can. people grind on the caliper to clear hx wheels. or run studs and spacers.
Old Mar 1, 2011 | 11:49 AM
night's Avatar
a 5mm spacer works just fine. uses original studs and easy
Old Mar 1, 2011 | 12:33 PM
blown_ss's Avatar
its not the caliber its the bracket.
Old Mar 1, 2011 | 12:34 PM
blown_ss's Avatar
i dont want to run a spacer. the wheels are 16x8 with a +20 offset.
Old Mar 1, 2011 | 12:46 PM
MR.johnson's Avatar
k talk a picture and show us where it needs to be ground down.
BIG T
Jul 7, 2013 11:05 AM
Droolin
Jun 2, 2011 09:32 PM
10psiLsEf2
May 24, 2011 08:20 PM
RyanH300
Jul 25, 2007 06:29 PM
stevescivic
15
Jun 6, 2004 09:47 AM
