obd2a d16y8 swapped into obd2b civic
Old Feb 28, 2011 | 02:29 PM
mcyang87's Avatar
Default obd2a d16y8 swapped into obd2b civic
like state i have a 96 d16y8 swapping it into 00 civic hb cx... i have the motor tranny obd2b dizzy and wire harness... gonna buy the 99-00 p2p ecu what else do i need to get the car running?
Old Feb 28, 2011 | 10:14 PM
EGfosho's Avatar
OG Tech
Default Re: obd2a d16y8 swapped into obd2b civic
You know you are just better of getting the 96-98 wire harness because the P2PA-12 ECU has a Fuel Tank pressure sensor which you car does not have. So you will always have a check engine light, unless you fool the ecu by give that pin a constant .5v. I would just get the dizzy and harness from the OBD2A and it will make life simple.
Old Mar 1, 2011 | 12:27 AM
ReDHaTcHyGuy's Avatar
^ the op's car is a 00... why would he get a 96-98 harness... just use a 99-00 ex harness , dizzy and ecu and you should be fine
Old Mar 1, 2011 | 07:35 AM
EGfosho's Avatar
OG Tech
I'm just telling him about the CEL he is going to get. I have a CEL right now which is code 91 and that what he will get also. I have a 00' D16Y8 with the 99-00 wireharness and ECU in my 99 Hatchback DX. I am in the middle of trying to fool the ECU so I don't get the 91 CEL.
Old Mar 1, 2011 | 01:28 PM
mcyang87's Avatar
would that CEL 91 cause the car not to start up then? or the car would still crank up...i know forsure the CEL is gonna be on since i don't have the 2nd O2
Old Mar 1, 2011 | 06:00 PM
EGfosho's Avatar
OG Tech
No, CEL 91 will have no effect at all until you have to do smog. I just don't like seeing a constant CEL while I drive. It annoys me.
Old Mar 1, 2011 | 06:35 PM
mcyang87's Avatar
well i guess i have to deal with the CEL light then
Old Mar 1, 2011 | 06:43 PM
Project Dad's Avatar
not to highjack, but since its part of the subject. How do you make the second o2 connection. I know the ex had the connector from the cab harness. mine is a 96 hx(don't have the y5)
Old Mar 1, 2011 | 07:19 PM
mcyang87's Avatar
good question...i been thinking about that question myself too
Old Mar 1, 2011 | 07:48 PM
well I saw the ex wire today. got a motor and tranny, had to pull it. but I know the y7 engine harness has both o2's on it
Old Mar 1, 2011 | 10:55 PM
tklee's Avatar
get OBD2A harness, everything should just plug and play
Old Mar 1, 2011 | 10:58 PM
EGfosho's Avatar
OG Tech
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
http://www.ff-squad.com/technet/code91.htm
http://www.ff-squad.com/technet/wiring.obd2b.htm
Old Mar 2, 2011 | 01:35 PM
mcyang87's Avatar
is that referred to the orginal topic question or the o2 question lol
smeags
25
Jul 18, 2013 06:05 PM
Eaglekper0046
Sep 27, 2005 09:41 AM
kholmes
Sep 20, 2004 01:00 AM
kholmes
Sep 19, 2004 07:40 PM
Soku1kcivic
Mar 25, 2002 09:07 PM
