Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 Civic Not Sure?
Old Feb 28, 2011 | 02:04 PM
Hondalala's Avatar
Default 01 Civic Not Sure?
I've got a 2001 Civic and when I'm driving in stop and go driving my car seems to overheat although the gauges are normal. The car starts rattling and when I hit the accelerator my car just shakes and barely moves. This only happens in stop and go traffic, my friend said it was the catylytic converter so we replaced it and still have the same problem. Are there 2 catylytic converters? Any suggestions would be great, thanks.
Old Feb 28, 2011 | 02:17 PM
Harlowe's Avatar
Function>Fashion
Default Re: 01 Civic Not Sure?
check your motor mounts maybe. could be part of the problem.
Old Feb 28, 2011 | 05:20 PM
toyomatt84's Avatar
Sanji
There is only one catalytic converter, and it's highly unlikely that it is the cause of the issue. I would suggest checking coolant coloration, Idle Air Control Valve cleanliness, when the vehicle last had it's water pump/timing belt replaced, etc...
Old Feb 28, 2011 | 06:39 PM
solidmaker's Avatar
is a check engine light coming on and when u changed the Catalytic converter did the rattling go away?
Old Feb 28, 2011 | 07:04 PM
lazlong's Avatar
First thing to check is to see if the radiator fan comes on when it's idling. If it doesn't, disconnect the fan connector and apply battery power to one terminal and ground to the other. As soon as both wires are connected the fan will run. If it doesn't run, replace it. If it does run, plug it back in and jump the temp switch to see if the fan runs. If the fan runs when you jump the switch, replace the switch.
Old Mar 1, 2011 | 12:56 PM
It Wasn't Me's Avatar
To add to what's already been said...
What makes you believe that the car is overheating? Are there any visible signs? Steam or spray from under the hood? Overflowing coolant reservoir?
If it were the catalytic converter, it'd do it all the time, not just in stop-and-go traffic.
Have you scanned the car for any stored codes? (even if the light never came on)
Is it an automatic or manual transmission?
NorPlan
Jan 12, 2016 04:42 AM
R.coustom
Mar 20, 2011 04:04 PM
shoprag
Sep 12, 2010 12:27 PM
zerovandez
10
Sep 10, 2005 04:56 PM
Accord_Munch
Nov 13, 2002 06:12 AM
