traction bar
Old Feb 28, 2011 | 09:14 AM
pleej's Avatar
Default traction bar
making some traction bars for my car and friends, what size are the rose joints people use m12 ?
Old Mar 1, 2011 | 11:16 AM
pleej's Avatar
Default Re: traction bar
any one ?
Old Mar 1, 2011 | 02:13 PM
98integralsB18's Avatar
some people call to them as Heim joints or Rod ends, but I believe I seen someone use 5/8's or 3/8s I wanna say 3/8. And I had another question while making the rods that the Heim joints go in instead of using a reverse thread on the one side could the side on the lower control arm be non-adjustable and just put a heim joint on the traction bar itself?
Old Mar 1, 2011 | 02:55 PM
5thgen's Avatar
I am going to use 1/2" rod ends.
The one side adjustable rod could be done, I guess. I think you would have a hard time getting the "fixed" joint to still swivel on 2 axes. Up and down having the most movement......I don't even know how much it would move left/right, couldn't be much if it moves at all.
Old Mar 1, 2011 | 03:11 PM
Yeah, I changed my mind I am going to use just left hand thread on it instead. of making it fixed. One more question how much money you guys got wrapped up in your bars?
Old Mar 2, 2011 | 09:16 AM
pleej's Avatar
i worked out about $50
Old Mar 2, 2011 | 10:16 AM
Sweet! For your rods did you weld nuts on the end or buy the bungs?
Old Mar 2, 2011 | 11:44 AM
Jenkinsal2's Avatar
50 dollars wouldnt even cover a good set of 4 rod end joints. I am curious where you ended up at this number?
Old Mar 2, 2011 | 12:01 PM
pleej's Avatar
lmao ok im lieing , only thing i paid for was the rose joints with the bungs
Old Mar 2, 2011 | 02:07 PM
haha, I have the tubing and plate steel to make brackets and stuff thinking around 100 or so if you had to buy everything.
Old Mar 2, 2011 | 03:02 PM
Jenkinsal2's Avatar
If you would like some more inspiration/help search for vectorsolid's write up on his homemade traction bar.
Old Mar 2, 2011 | 03:15 PM
found it>https://honda-tech.com/forums/suspension-brakes-54/traction-bar-made-my-own-2819949/
Tippyman
Welding / Fabrication
Jul 19, 2014 03:05 PM
JustinHoMi
Suspension & Brakes
Mar 9, 2006 09:35 AM
durand202
Jun 10, 2005 06:00 AM
gsr2envy
Nov 8, 2004 11:58 AM
Mr.Saturn
11
Feb 23, 2004 11:52 PM
