Ac Bracket and Compressor for B16 Eg Question URGENT
Old Feb 28, 2011 | 08:12 AM
REDEM1FTW's Avatar
Icon3 Ac Bracket and Compressor for B16 Eg Question URGENT
I have searched and I know this has been covered many times but I cannot find a clear answer.
I have a b16 swapped eg and want to install ac but I do not know which bracket/compressor combo I need.
- Brackets -
1. If I want to use a b series compressor, which bracket do I need?
2. If I want to use a d series compressor which bracket do I need?
- Compressor -
1. If I use the b series compressor, which lines will be different from the stock eg lines?
2. If I use the d series compressor will I be able to use all stock lines and ONLY have to change brackets?
Im about to head to the junkyard in a couple hours so any help is appreciated!
Thanks,
Josh
Old Feb 28, 2011 | 08:27 AM
94EG8's Avatar
Seagull Management
Default Re: Ac Bracket and Compressor for B16 Eg Question URGENT
You'll need a bracket for a '94 - '97 Del Sol VTEC good luck finding one in a junkyard. '97 - '01 CR-V bracket works too but it may cause clearance issues with the P/S bracket on a B16A due to the shorter deck height. Either one of those two brackets will let you use a D-series A/C compressor, using a B-series compressor involves using B-series lines IIRC.
Old Feb 28, 2011 | 09:15 AM
REDEM1FTW's Avatar
So if im not running P/S I should have no trouble running the crv bracket? And what code will be on the crv bracket? (PJ7 or P54)?
Old Feb 28, 2011 | 11:18 AM
egsleepercivic's Avatar
crv bracket is fine if you are using a D compressor, I have one on my B16a, its the same as the del sol just cheaper
Old Feb 28, 2011 | 11:39 AM
94EG8's Avatar
Seagull Management
Yes.
I can't remember right off what the code is.
Old Feb 28, 2011 | 11:51 AM
REDEM1FTW's Avatar
I just read that a P30 bracket will work also if im using d series compressor/components, any info on this? I found one for $15 so if itll work ill go scoop it up
Old Feb 28, 2011 | 11:57 AM
94EG8's Avatar
Seagull Management
Don't believe so. I have one here, if I can find a D-series compressor i'll try to see if it fits tommorrow, almost positive it doesn't though.
Old Feb 28, 2011 | 12:03 PM
P30 bracket comes on the JDM b16a and do not work with a d compressor, I have one in my garage
Old Feb 28, 2011 | 12:13 PM
TriedAndTrue's Avatar
The 94-97 del sol bracket that will work has the code p54... The crv bracket that will work has the code p7j
*edit* both of those will work with your d series compressor..
dijitalbuddhist
15
Mar 3, 2014 09:33 PM
moco_machine
Sep 4, 2009 07:26 PM
jaredvabeach
Jun 11, 2008 06:05 PM
dE.fUsEd
Jul 7, 2007 09:56 AM
slowpokesi
17
Jul 20, 2002 08:31 AM
